Disassembling Old Potentiometer Volume Control
KimR
Post16-10-2007, 19:59    Subject: Disassembling Old Potentiometer Volume Control Quote
Does anyone here know how to remove the potentiometer arm from the very old MSW potentiometer?
I tried it on a broken one. But it fits very TIGHT!
It looks like he's simply pressed against the wave. Maybe due to a temperature change!
Translated on 20-10-2026, 16:04.
wolfi_b
Post17-10-2007, 8:40    Subject: Disassembling Old Poti Quantity Control System Quote
KimR wrote:
It looks like it's simply pressed against the wave.
Maybe due to a temperature change (warm/cold)!icon_sad.gif
Yes, it seems that's the case, so I left it and got a new MSW }.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 20-10-2026, 16:05.
cksIT
Post17-10-2007, 9:09    Subject: Disassembling Old Potentiometer Volume Control Quote
Are you talking about a VP37 MSW?
"Yes, I carefully gripped it with pliers and pulled it off... It's more stable than it looks."
KimR
Post17-10-2007, 11:06    Subject: Disassembling Old Potentiometer Volume Control Quote
Are you now talking about a VP37 MSW?
If so, I carefully gripped it with pliers and pulled it off... It's more stable than it looks.
Ja korrekt VP37 MSW ! Aber der alten mit Poti drin. Not HDK!
The MSW test is broken now! The potentiometer arm is broken. I've tried so much. Most recently, the plastic part of the potentiometer arm broke. And now, the metal part is still attached to the shaft.
And it's so stuck. I can't get it unstuck from the wave.
I can turn it, but it won't start.
That's a pain. Maybe it's easier to convert the car to an HDK MSW system. Use the wiring harness and control unit from a 1Z model, and of course, an HDK MSW unit!
Has anyone tried something like this before?
Translated on 20-10-2026, 16:06.
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts LMM for 1Z: Refurbished & Optimized:-) Diesel Engine Technology
No new posts LMM Connector: 6-Pin to 5-Pin Adapter Conversion Diesel Engine Technology
No new posts MKB 1Z Error Codes: Slider Position Potentiometer - G99 Diesel Engine Technology
No new posts ESP comparison > Poti and... HDK Sensors Diesel Engine Technology
