robidobi007 Blaumann
Joined: 10/13/2007 Posts: 30 Karma: +2 / -0 Location: Fürstenberg/Havel
13-10-2007, 11:07 Subject: Exhaust Smoke: High Emission at Full Load |
Hello, I'm new here.
I have a problem: my 1.9 TDI has been producing a lot of black smoke since I bought it, especially under partial load and also under full load.
Vag-com is available, and logs can be created, but I'm not sure which ones would be best to use.
LMM seems to be working fine for now, as the performance is good.
As far as I know, the turbocharger boost pressure was fine back then, around 0.7-0.8 bar max, which is above atmospheric pressure. But I'll double-check that.
Okay, I've already deactivated the AGR valve, removed the vacuum hose, and sealed it. Of course, it's possible that something is still stuck and causing the reversion? But I don't want to remove it yet; I want to do a diagnosis with VAG-COM first.
MKB AJM.
Bora Variant 1.9 TDI PD 115PS 310Nm @ 1900 1/min
Translated on 25-10-2026, 10:27.
Profile PM Email |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
13-10-2007, 12:19 Subject: Exhaust Smoke: High Emission at Full Load |
Take a look at the technical articles on systematic troubleshooting with VAG-COM. Then, perform the logs described there, present them here in a well-organized manner, and you will certainly be able to get help without much speculation.
Don't forget to include all the vehicle details, including any information about chips or tuning boxes.
Anything else would be like looking into a crystal ball.
Okay.
Translated on 25-10-2026, 10:29.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
13-10-2007, 19:01 Subject: Exhaust Smoke: High Emission at Full Load |
guste100 wrote: |
Greetings. Good | = the Good Guste:P.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 25-10-2026, 10:30.
Profile PM Email Garage |
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-10-2007, 19:03 Subject: Exhaust Smoke: High Emission at Full Load |
..and Quote: | | ag so at 0.7-0.8 bar max | is much too low for the AJM. Measurement block 11 will tell you the target value and the actual value.
Profile PM WWW Garage |
13-10-2007, 20:36 Subject: Exhaust Smoke: High Emission at Full Load |
@guste
Sorry, maybe I'm being dense, but I can't find one like that, or anything suitable. I've already found the technical articles, but nothing that could help me.
I would like to log everything we need tomorrow, but what measurement blocks should I use?
Translated on 25-10-2026, 10:31.
Profile PM Email |
vagtuning Guest
13-10-2007, 20:38 Subject: Exhaust Smoke: High Emission at Full Load |
13-10-2007, 21:39 Subject: Exhaust Smoke: High Emission at Full Load |
Thank you for your quick help, @vagtuning.
"As the saying goes: those who can read are clearly at an advantage... I had this thread open before, but I overlooked it at the beginning and only read about the symptoms... Well, I'll definitely learn about it sometime  ."
Translated on 25-10-2026, 10:32.
Profile PM Email |
14-10-2007, 8:49 Subject: Exhaust Smoke: High Emission at Full Load |
Hello, I've created the logs, and you can find them at the following link.
/viewtopic.php?t=17004
I also performed an acceleration measurement.
- a straight stretch of road, several kilometers long.
- No curves, mountains, or anything like that.
- In 3rd gear, at approximately 1200 RPM, logging with cylinder misfire codes 5 and 6, full throttle up to approximately 5000 RPM.
- Then, depress the clutch and let the car roll to a stop at approximately 70 km/h.
Volkswagen Bora Variant 1.9 TDI Highline.
-115 hp
-310 Nm
I have indicated the vehicle weight as 1450 kg.
Fuel with a weight of 15 kg.
Driver weight: 70 kg.
other, 20.
Temp 1 degree.
Here's the translation:
"As a result, the following emerged."
/download.php?id=2505
Translated on 25-10-2026, 10:33.
Profile PM Email |
