Modify STG 46 settings
coupe 2,3
Post24-09-2007, 14:55    Subject: Modify STG 46 settings Quote
I want to encode the value 0 as 46-Function10-Channel 61, and the value 2 as 46-Function10-Channel 61.
...but is it not saved?
--AUDI A4 2.0 TDI, 10/2005
What am I doing wrong?
It would be nice if someone could help me.
Translated on 23-07-2026, 5:21.
Ross-Tech-Support
Post24-09-2007, 16:26    Subject: Modify STG 46 settings Quote
Which version of VAG-COM are you using?
Translated on 23-07-2026, 5:22.
coupe 2,3
Post24-09-2007, 17:13    Subject: adjust parameters Quote
Hello.
VAGCOM RKS 704.1
Ross-Tech-Support
Post24-09-2007, 17:17    Subject: Modify STG 46 settings Quote
Please do the following:
VAG-COM > Selection > 46 - Comfort System > Fault Memory - 02 > Copy/Save Error Codes.
"...and then insert it here" (even if no error codes are stored).
Translated on 23-07-2026, 5:23.
coupe 2,3
Post24-09-2007, 17:25    Subject: Modify STG 46 settings Quote
I'll try it out tonight.
Thank you for the quick response.
coupe 2,3
Post24-09-2007, 20:57    Subject: Modify STG 46 settings Quote
Hello.
I followed your instructions, but I can't make any changes there?
I tried this.
VAGCOM > Control Unit > 46 Comfort > Adaptation > 61 > changed "o" to 2 > test > save.
Unfortunately, the number "2" was not saved, and now there are questions upon questions.
Translated on 23-07-2026, 5:24.
Post24-09-2007, 21:25    Subject: Modify STG 46 settings Quote
Sebastian means something different!
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Automatikschaltsoftware ändern?! Diesel Engine Technology
No new posts Adjust idle speed On-Board Diagnostics (OBD)
No new posts Auxiliary Heater T5: Activation Conditions Changed On-Board Diagnostics (OBD)
