jerky automatic transmission
roorback
Karma: +1 / -2   Thank you, like it!
Post30-09-2007, 11:33    Subject: jerky automatic transmission Quote
hello,
I hope there are some automatic transmission specialists here who can help me. I have a Volvo V70 TDI (2.5 AEL) with an automatic transmission.
"This one drives pretty well, the shifting is smooth - everything seems to be okay."
"It only happens when I'm driving and release the accelerator; the engine speed slowly drops to idle, and at that exact moment, the car often jolts quite strongly (only in 'D' mode)."
If I shift into neutral and let the car idle, there is no noticeable jerking.
Thank you for the tips!
best regards, uwe
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post30-09-2007, 22:08    Subject: jerky automatic transmission Quote
Hi, since you have a motor from a VW/Audi Regal, I assume it's a 5-speed Tiptronic transmission from ZF?
If so, take a look here:
http://www.passat3b.de/phpBB2/viewtopic.php?f=18&t=11295
EDIT:
Oops, model year 1997, so it's more likely a 4-speed automatic, but maybe it's from ZF?
Sven.
Passat Variant Highline 2,0 TDI 103KW
roorback
Post01-10-2007, 10:51    Subject: jerky automatic transmission Quote
hello,
Volvo has its own transmissions.
Okay, personally, I would suspect the mass airflow sensor. I had a similar issue with my other TDI, and it was cleaned and adjusted, which resolved the problem.
But why does it only happen in the "D" position, and not in the "N" position when rolling?
You're very welcome.
best regards, uwe
Avatar-Jan6K
Post01-10-2007, 15:01    Subject: jerky automatic transmission Quote
I don't really know much about automatic transmissions, but do they also provide something like engine braking in "D" mode? In that case, depending on the transmission's control system, the engine might switch to a "cut-off" mode. If it doesn't do that, or if it's oscillating between idle and thrust cutoff, then I believe that could certainly explain the jerking.
At speed N, the power flow is disconnected, meaning the motor can do whatever it wants without affecting the car's acceleration or deceleration.
Jan.
1Z5 CFHF / AHB H4D
roorback
Post01-10-2007, 18:23    Subject: jerky automatic transmission Quote
Thank you for your tip.
Well, the jerking is noticeable even at higher RPMs when I release the accelerator.
I've heard something about brake bands in the automatic transmission. I think I need a specialist for something like that icon_sad.gif.
best regards, uwe
roorback
Post03-10-2007, 17:23    Subject: jerky automatic transmission Quote
hello,
Okay, so it seems the problem is related to the engine braking. Yesterday, I was driving in first gear (or "L" gear, as it's called in my car) down a hill, and it was trying to brake more, but there was a lot of jerking and absolutely no engine braking effect.
As I said, everything else works perfectly fine.
Does anyone have any ideas?
"Thank you."
best regards, uwe
No new posts 1Z Engine Problems: Troubleshooting & Repair Diesel Engine Technology
No new posts Gentle shaking Diesel Engine Technology
No new posts Why is only 1Z stuttering? Diesel Engine Technology
No new posts Passat 1.9 TDi AVF 130PS - experiencing vibrations/jerking Upload
