Intake valve not closing long enough, causing engine shake!
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post02-10-2007, 19:40    Subject: Intake valve not closing long enough, causing engine shake! Quote
Hi, my engine has been shaking a bit more than usual when I turn it off lately.
The intake valve should close for 3 seconds.
"...for me, it's about 0.5 seconds when turning off the engine... that's too short!!"
I performed an actuator diagnosis, and the solenoid valve for the throttle seems to be okay, or at least it's making a sound when it switches, but I'm not sure if it's working correctly.
What else could I check?
[img=http://srv010.%=srvName %>/20071002194139410_hpgiqurqvg.jpg]
[img=http://srv007.%=srvName %>/20071002194509409_eznodrqnkl.jpg]
I just compared it to a TDI ALH engine from a friend's car, and in that case, the valve closes for exactly 3 seconds...
Where could the error be?
Sven.[/img][/img]
Passat Variant Highline 2,0 TDI 103KW
Translated on 23-07-2026, 8:36.
scrdel
Post06-10-2007, 13:44    Subject: Intake valve not closing long enough, causing engine shake! Quote
.... no one knows a solution new_shocked.gif.
Sven.
Translated on 23-07-2026, 8:38.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post06-10-2007, 14:13    Subject: Intake valve not closing long enough, causing engine shake! Quote
Perhaps there's a leak in the vacuum supply line to the control valve?
Avatar-Jan6K
Post06-10-2007, 14:32    Subject: Intake valve not closing long enough, causing engine shake! Quote
Perhaps there's a general leak in the vacuum system? In my case, the plastic hose to the brake booster was brittle (I can't understand how they could install such poor quality parts), which caused the vacuum to bleed off very quickly when the engine was turned off.
You can easily test this: Turn off the engine, wait ten seconds, and press the brake pedal. If the pedal is rock hard, then you have lost a significant amount of vacuum pressure. With a functioning system, there should still be enough vacuum pressure left even the next day so that you can at least press the brake pedal with power assist once or twice (with the engine off).
You can easily spot major leaks... have someone turn off the engine while you stand next to it. A hissing sound will reveal the source of the leak.
Jan.
1Z5 CFHF / AHB H4D
Translated on 23-07-2026, 8:40.
scrdel
Post06-10-2007, 16:54    Subject: Intake valve not closing long enough, causing engine shake! Quote
Thanks everyone, I'll check the car and those points tomorrow.
"Every morning, I notice that the brake pedal feels very hard. I'm going to check it out."
Sven.
Translated on 23-07-2026, 8:42.
Avatar-Jan6K
Post06-10-2007, 18:22    Subject: Intake valve not closing long enough, causing engine shake! Quote
Well then... that's almost certainly the case.
Take a look at the thick black hose that goes into the brake booster...
Jan.
1Z5 CFHF / AHB H4D
Translated on 23-07-2026, 8:43.
scrdel
Post07-10-2007, 10:02    Subject: Intake valve not closing long enough, causing engine shake! Quote
... I just came back from the car; it had been parked overnight, and the brake pedal is completely stiff.
I then disconnected the hose from the N 236 that goes to the throttle valve and tried to create a vacuum by mouth first, then with a syringe, to see if the valve would move.
... luckily, it moved about 2-3 millimeters, but I couldn't maintain the vacuum pressure.
I removed the pressure sensor and opened it up, and I saw a crack, about 2 centimeters long, in the rubber membrane.
Once I get my camera back, I'll take a picture.
Bug fixed, user happy icon_razz.gif.
/my.php?image=abstellklappesaugrohrkljx1.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img103/428/abstellklappesaugrohrkljx1.th.jpg" class="responsive" alt="http://img103.
/img103/428/abstellklappesaugrohrkljx1.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Now I need to find out where I can get the part. I once read that Volkswagen's experts only sell the canister as a complete unit, along with all the associated AGR components, for a huge amount of Euros.
Does anyone perhaps have one lying around icon_biggrin.gif?
Certainly, I would like to thank you all, especially Jan6K for his help.
EDIT:
Here are the photos; some of them are already on their way to me from eBay for a small price...
/my.php?image=p1010178kt4.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img122/4494/p1010178kt4.th.jpg" class="responsive" alt="http://img122.
/img122/4494/p1010178kt4.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
/my.php?image=p1010177tt3.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img227/2245/p1010177tt3.th.jpg" class="responsive" alt="http://img227.
/img227/2245/p1010177tt3.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Sven.
Translated on 23-07-2026, 8:47.
No new posts Doku A4 8D ab MJ 2000, Motor STG läßt sich nicht an WFS... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW V6 TDI: Glow Plug Issues & Solutions Diesel Engine Technology
No new posts A4 is shaking Transmission, Chassis, Body & Interior
No new posts Polo 9N automatically locks itself On-Board Diagnostics (OBD)
No new posts BDG Engine: Enough Power? Diesel Engine Technology
