dj1 Guest
10-07-2006, 15:11 Subject: Turning a pressure vessel on a VNT20... |
I want to relocate the pressure sensor from the VNT20.
I'd like to ask if anyone has done this before, and what I should be aware of.
I've already figured out this much, but I'm not sure what is meant by the 'entire VTG ring.'
The exhaust side needs to be rotated, including the entire VTG (Variable Turbine Geometry) unit.
Some people claim you can't turn them, but that's not true; you just have to...
1. Carefully open the exhaust housing.
2. Remove the entire VTG ring and screw it back in one position further.
You can then simply screw the pressure vessel onto the next hole.
'Dj'
Translated on 04-07-2026, 9:40.
dj1 Guest
10-07-2006, 15:34 Subject: Image |
I've attached another picture.
Do I need to loosen the screws that I've circled in red, or just rotate the VTG ring (blue)?
DJ
| Description: |
| File size: |
579.52 KB |
| Viewed: |
2265 times |
Translated on 04-07-2026, 9:42.
10-07-2006, 15:53 Subject: Turning a pressure vessel on a VNT20... |
HI,
A quick question: Were those grease stains already there from the factory?
Thank you.
martin
Profile PM Garage |
dj1 Guest
10-07-2006, 21:28 Subject: Turning a pressure vessel on a VNT20... |
HI,
Thank you.
martin
I have no idea; the image is not mine.
I will be careful not to open my VNT20 until I know how to properly adjust the pressure sensor.
Okay, hier ist die Übersetzung:
'Dj1'
Translated on 04-07-2026, 9:43.
dj1 Guest
11-07-2006, 17:20 Subject: Turning a pressure vessel on a VNT20... |
Okay, I've taken a closer look at the VNT20  .
Since I want to install a turbocharger on a Golf 3 AFN, I need to rotate the pressure sensor so that it points upwards.
I disassembled the turbo today.
When I removed the exhaust housing, I immediately noticed that it doesn't use the Mozz hex screws that hold the entire VTG ring in place, but instead uses Torx screws (see picture 2).
I thought there wouldn't be any other differences, but there are!
and namely:
To rotate the pressure sensor, it is necessary to completely disassemble the compressor and exhaust housing.
After that, unscrew the entire VTG ring (3 screws) and then screw it back on, but one position further.
This applies to all VNT20 models where the three screws that hold the VTG ring are symmetrically arranged (see image 1).
They don't fit with mine! That's why only 2 screws fit the VTG ring. Well, I can't just leave it like this...
You could now drill a hole with a thread and screw the third screw in there (see picture 4), but will that cause any cracks?
I generally don't like drilling into exhaust housings.
What do the experts say? Can I cut such a thread into the exhaust housing without any negative consequences?
DJ
| Description: |
| File size: |
230.65 KB |
| Viewed: |
2018 times |
| Description: |
| File size: |
269.74 KB |
| Viewed: |
1912 times |
| Description: |
| File size: |
322.96 KB |
| Viewed: |
2020 times |
| Description: |
| File size: |
257.87 KB |
| Viewed: |
1831 times |
Translated on 04-07-2026, 9:45.
mhernach Guest
12-07-2006, 6:46 Subject: Turning a pressure vessel on a VNT20... |
Hello...
Wouldn't it be advisable to drill the holes?
In picture 2, you've drawn red circles...
If I align it correctly, it should work like this...
I hope I'm not wrong now  .
Translated on 04-07-2026, 9:47.
dj1 Guest
12-07-2006, 17:52 Subject: Turning a pressure vessel on a VNT20... |
Hello...
Which holes should I drill?
Only one hole is no longer working when I turn the VTG ring.
And even if I drill it, it won't be better, because I need the hole with the thread to be shifted about 1 cm to the right (see attached image).
DJ
| Description: |
| File size: |
256.96 KB |
| Viewed: |
1440 times |
Translated on 04-07-2026, 9:48.
mhernach Guest
13-07-2006, 6:16 Subject: Turning a pressure vessel on a VNT20... |
No, that's not what I meant.
Look at this...
[img][/img]
If you drill a new hole, I don't think anything should happen.
Unless the holes are intentionally placed..., but I can't see that in this photo...
Michael.http://www.mhernach.com/fotos/galaxy/6b.jpg{MARKER}
Translated on 04-07-2026, 9:49.
dj1 Guest
13-07-2006, 18:38 Subject: Turning a pressure vessel on a VNT20... |
Okay, after a lot of consideration, I've decided to leave the turbo as it comes from VW, or as it is originally.
If I keep it as is, I'll have to redesign my adapter.
My question:
Is it a problem if the exhaust gases have to travel a short distance upwards before reaching the turbo?
I imagine it's something like what's shown in my sketch (see attachment).
What do you think about it?
Please provide suggestions and tips.
Sure, here's the translation:
'Thank you in advance!'
DJ1
| Description: |
| File size: |
44.65 KB |
| Viewed: |
5080 times |
Translated on 04-07-2026, 9:50.
mhernach Guest
14-07-2006, 5:13 Subject: Turning a pressure vessel on a VNT20... |
Nice drawing  .
Well, I suppose it would be better to position the turbocharger as close as possible to the cylinder.
But it could also work that way.
Why do you actually want to move your printer, don't you have enough space?
Michi.
Translated on 04-07-2026, 9:51.
14-07-2006, 6:36 Subject: Turning a pressure vessel on a VNT20... |
dj1 wrote: | Is it a problem if the exhaust gases have to travel a short distance upwards before reaching the turbo?
I imagine it's something like what's shown in my sketch | .
"By adding an additional pipe section, the contribution of pressure waves to the engine's drive system will likely be reduced, as the pressure waves from the individual cylinders will dissipate within the additional volume of the pipe." Translation: The turbo lag will become even more pronounced, something that was already unavoidable due to the switch to the VNT20.
Are you rotating the loader on your machine relative to its normal mounting position?
If the oil flow direction through the pump (normally from top to bottom) is significantly altered, I'm not sure if this could cause any problems.
Translated on 04-07-2026, 9:52.
Profile PM Garage |
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
14-07-2006, 6:37 Subject: Turning a pressure vessel on a VNT20... |
Okay, so, is the VNT20 the one I have installed, or am I mistaken? If so, on mine, the exhaust manifolds are inside the downpipe, and the turbo is mounted on top of it. The turbo "sits" between the two cylinder banks, higher than the exhaust manifolds. It's similar to your drawing, and your pipe bend is my downpipe. The mounting position of the turbo also seems to be the same. Therefore, it probably won't be a problem.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 04-07-2026, 9:54.
dj1 Guest
14-07-2006, 8:13 Subject: Turning a pressure vessel on a VNT20... |
Hello everyone,
@mhernach:
Since I'm not going to use a turbocharger with a wastegate, I need to build the turbocharger exactly as it is in my sketch.
Make sure the oil drain, inlet, and pressure sensor are all facing the correct direction.
@Ulf: Initially, I wanted to rotate the compressor housing and then install the turbo in the same way as the original VNT15 was installed. Since modifying it like that would be too complicated and too dangerous for me, I'll leave the turbo as it comes from VW and try to adjust everything else.
I'm trying to make the adapter as short as possible.
I'm very excited to see how it performs.
Thank you for your tips!
DJ
| Description: |
| File size: |
515.46 KB |
| Viewed: |
1372 times |
| Description: |
| File size: |
332.25 KB |
| Viewed: |
1244 times |
Translated on 04-07-2026, 9:55.
dj1 Guest
14-07-2006, 19:53 Subject: Turning a pressure vessel on a VNT20... |
So, the VNT20 is the one I have inside, or am I wrong? If so, in mine, the exhaust manifolds are in the downpipe, and the turbo is on top of it. The turbo 'sits' between the two cylinder banks, higher than the exhaust manifolds. It's similar to your drawing; your bend is my downpipe. The mounting position of the turbo also seems to be the same. Therefore, it probably won't be a problem.
Can you please send me some photos of your installed turbo (VNT20) in the engine bay? That would be very interesting to me.
Perhaps also from the exhaust manifold or the downpipe.
DJ1
Translated on 04-07-2026, 9:57.
15-07-2006, 6:02 Subject: Turning a pressure vessel on a VNT20... |
Sure, I can do that. I'll send you a direct message (DM) once I've done it. I have no idea if it will help you. I'll definitely remove the engine cover. I'll also remove the metal plate on the turbo. However, even then, you won't have an optimal view, and I won't disassemble my car any further. I'm glad it's finally running again  . Also, check out 3,2,1. Sometimes, you can even find trouser legs with prints on them.
Aktuell:
Translated on 04-07-2026, 9:59.
dj1 Guest
16-07-2006, 21:43 Subject: Turning a pressure vessel on a VNT20... |
@Mr. Antje:
hey, you don't need to completely disassemble your car  .
Take off your cover and take some pictures, it will be fine  .
Best regards and thank you.
DJ
