Steering Angle Sensor: What Does It Measure?
Kruegerjean
Post22-04-2005, 14:44    Subject: Steering Angle Sensor: What Does It Measure? Quote
I installed an aftermarket cruise control system. Everything seems to be working well. When removing and reinstalling the steering wheel, I made sure that the steering wheel was straight and reinstalled it in its original position. The steering column was not moved during this process. However, the steering wheel was turned one full rotation to the right.
Now I've read the installation instructions again, and it says that you should make sure the wheels are straight because of the ESP sensor.
Now my question: Is there a risk that the ESP sensor will now report an incorrect steering angle? (i.e., rotated by 360 degrees)?
Is the absolute steering angle actually measured, or only the change/speed at which the steering wheel is turned?
In my opinion, everything should be fine, as the sensor plate was reattached in exactly the same way as it was previously removed. However, I would appreciate a confirmation or correction from you.
Thank you very much.
Jean.
Translated on 10-10-2026, 13:42.
StefanS
Post22-12-2007, 18:44    Subject: Steering Angle Sensor: What Does It Measure? Quote
I suspect that if the sensor wasn't installed correctly, an error would be triggered at the latest when the steering wheel is fully turned to the right or left, because the value would be outside the possible range.
My advice is to always ensure the wheels are pointing straight ahead before removing the steering wheel.
I recently had a problem installing the SRS cassette on a Sprinter, and it was only because I had slightly rotated the steering wheel to better access the screws for the airbag. Subsequently, when removing the steering wheel, it wasn't perfectly straight. It took me about fifteen minutes to properly reinstall the cassette.
In addition, always follow the manufacturer's instructions when disassembling ABS units. Usually, disconnect the battery and wait a short time before disconnecting the ABS unit.
Translated on 10-10-2026, 13:44.
heizfoss
Karma: +4 / -1   Thank you, like it!
Post22-12-2007, 20:27    Subject: Steering Angle Sensor: What Does It Measure? Quote
Hello Kruegerjean!
The steering angle sensor is used in vehicles equipped with ESP (Electronic Stability Program). The ESP system has a specific characteristic curve for the single-track model (based on Ackermann) stored within it. This curve indicates at which steering wheel angle the vehicle can navigate a particular curve "stably." If the measured yaw rate (from the yaw rate sensor) does not correspond to the steering angle and the single-track model, the ESP detects either understeer (the steering angle is greater than the vehicle's yaw rate) or oversteer (the vehicle's yaw rate is greater than the steering angle), and counteracts this undesirable behavior by adjusting the brake pressure.
The steering angle sensor must be relatively accurate. Even slight deviations (e.g., different tire pressures, minor misalignment caused by driving over a curb) are compensated for by a steering angle sensor offset adjustment (learned while driving straight on the highway, validated by a lateral acceleration value of approximately 0).
If the deviations are too high (e.g., due to incorrect installation), the steering angle offset cannot be automatically learned. The offset can be calibrated using VAS (e.g., after replacement).
icon_eek.gif However, if you actually installed it incorrectly by 360°, you would have a corresponding error message:
"Steering angle sensor: implausible signal" and the ESP (Electronic Stability Program) was deactivated (ESP light illuminated).
The ESP system, for example, detects an "aggressive turn" with a 360-degree steering angle at 360° if there is a misconfiguration, without any lateral acceleration occurring, which is certainly physically implausible.
"With a slight misalignment (a few degrees), you can check the correct calibration in the measurement data block (I don't know the exact number offhand) of the ESP, assuming the steering is aligned correctly (the value should be close to zero). If there are any deviations, you can then calibrate it (feel free to ask me how if it's necessary). However, I think everything is fine with yours."
Merry Christmas.
heating fossil.
icon_smile.gif Spritsparen durch Ausnutzen der Querbeschleunigung - lieber tot als Schwung verlieren
Translated on 10-10-2026, 13:47.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measuring Ambient Pressure in MSG: How It's Done On-Board Diagnostics (OBD)
No new posts VP-xDI Compression: How is it Measured? Diesel Engine Technology
No new posts Noise when steering at full lock Diesel Engine Technology
No new posts Limit Steering Angle Golf IV TDI Transmission, Chassis, Body & Interior
