Audi A3: Warm Start Problems & Solutions
smartens
Post11-12-2002, 23:08    Subject: Audi A3: Warm Start Problems & Solutions Quote
My A3 takes 6-7 seconds to start when it's warm.
He starts up.
Cold zero problem.
Self-diagnosis revealed that the control unit is locked.
However, I don't believe this is the cause.
Problems with the immobilizer usually manifest differently, right?
Once the engine starts, it runs perfectly fine.
But surely, it can't start in a warm state like that.
be normal.
Does anyone have any advice?
Translated on 26-10-2026, 15:51.
Post12-12-2002, 17:46    Subject: How to...: Easy Guides & Tutorials Quote
Hi.
. . . if you could first tell us what kind of engine you have?
Possible causes depend on that icon_idea.gif.
Translated on 26-10-2026, 15:52.
Post12-12-2002, 17:53    Subject: Audi A3: Warm Start Problems & Solutions Quote
/viewtopic.php?t=147
das schon abgecheckt ? Result?
jens712001
Post19-12-2002, 21:31    Subject: Audi A3: Warm Start Problems & Solutions Quote
'Try disconnecting the coolant temperature sensor. If the engine starts immediately, it's usually due to a low cranking speed, which is compensated for by a larger fuel injection amount during startup. Replacing the battery might provide a temporary solution, but in my experience, the starter motor needs to be replaced. It's very difficult to detect the low cranking speed by simply listening; you might think it's starting normally. However, I've personally replaced about 10 starter motors due to this issue, and everyone has been satisfied with the result!'
Translated on 26-10-2026, 15:53.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi A3 BMN Engine: Cold Start Problems Diesel Engine Technology
No new posts TDI Conversion: VW Bus Cold Start Problems Diesel Engine Technology
No new posts TDI ECU Reprogramming: Fix Warm Start Issues On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Warm-start problem of a different kind (SOLVED) Diesel Engine Technology
