Climate System Fails to Communicate with VAG-CCOM
chli1976
Karma: +185 / -0   Thank you, like it!
Post06-11-2007, 22:23    Subject: Climate System Fails to Communicate with VAG-CCOM Quote
Hello.
I'm trying to read the diagnostic data blocks of the climate control module in a 2000 Audi A3 because it's not regulating the temperature correctly, but unfortunately, the connection keeps dropping. I can access all the other control modules without any problems.
I can access the climate control system, but when I try to read the measurement data blocks, I can sometimes access it, but after a short time or immediately, I get an error message: "ERROR UNKNOWN MESSAGE TYPE 0X33" in the four columns.
Mir ist noch aufgefallen das beim Komunikationsstatus folgendes steht. IC1 TE16 RE0
The first and last ones are the same in other models as well, but instead of "TE16", they have "TE0".
I'm using a HEX-CAN Version 704.1, and I've also tried the beta version 710. I've tested it with both a laptop and a standalone PC, and I'm getting the same result in both cases.
Thank you.
Translated on 17-09-2026, 0:37.
Post06-11-2007, 23:45    Subject: Climate System Fails to Communicate with VAG-CCOM Quote
You have a private message.
Translated on 17-09-2026, 0:38.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not working properly Diesel Engine Technology
No new posts 1Z is not working correctly Diesel Engine Technology
No new posts ARL läuft nicht richtig...? On-Board Diagnostics (OBD)
No new posts A3 AI cannot be properly encoded Gasoline Engine Technology
