Okay, thank you!
I thought that because the injected amount might pass through the nozzle faster, the injection end would be before the normal end, and therefore the start of the injection might have been delayed slightly to still reach the optimal "center." However, I suspect that the tolerance range is so large that the deviation doesn't matter
Once all my repair work is completed, I will definitely reach out to you again - a corresponding software adjustment (chip tuning) could certainly be beneficial in that case
