Engine Block Clutch Bell Diagram
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post07-05-2008, 12:50    Subject: Engine Block Clutch Bell Diagram Quote
At VW, you can still find the 1.9L TDI with the VP37, although it's only available as an industrial engine.
see here
http://www.vw-industrial-engines.com/industriemotoren/motoren/dieselmotoren/tdi-19-463-mb/index.html?L=0
Is the gear ratio diagram identical to the last VPE-1.9 (MKB ASV) from the automotive sector?
Thank you and best regards.
Jens
Frank A.
2000 Volkswagen Golf
Post07-05-2008, 14:03    Subject: Engine Block Clutch Bell Diagram Quote
The part number for the motor is the same as for MKB ALH.
so ist der Block identisch.
Best regards, Frank
No new posts Doku Ölverlust am Motorblock, AFB- und AKN-Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALH: OT-Loch der Kupplungsglocke -> wo? Diesel Engine Technology
No new posts Motorblock hat ab 110000 km einen 3 cm riss Diesel Engine Technology
No new posts Motorhalter - Auge am Motorblock abgerissen Diesel Engine Technology
No new posts Paßt der Zylinderkopf vom AAT auf einen 1T-Motorblock ? Diesel Engine Technology
