Uneven Performance: Causes and Solutions
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
oschoppm
Post25-11-2007, 23:32    Subject: Uneven Performance: Causes and Solutions Quote
Hello everyone, I have an AFN engine in a T3 Doka http://www.feine-busse.de. After the timing belt broke, everything is new now... but it no longer has satisfactory performance:
1. It starts poorly.
2. Exhibits fluctuating performance across the entire RPM range.
3. The ESP was installed and empty for 5 months.
4. No smoking... or at least very little (without EGR).
5. No informative error message in memory.
I suspect the injector driver in the ESP system is responsible for controlling the injection timing, but I'm not sure. I have a log file, but I couldn't properly analyze it, so here it is in its raw form:
I urgently need help!
Saturday, October 13, 2007, 3:30:53 PM
E88 BD0 06, 1.9L R4 EDC, G00SG, 1619.
Group A: ,'001,,,,Group B: ,'002,,,,Group C: ,'004,,
,,RPM,Inj. Quantity,Voltage,Temperature,,RPM,Load,Bin. Bits,Temperature,,RPM,Ign. Timing,Ign. Timing, Duty Cycle.
TIME,,,,,TIME,,,,,TIME,,,,
MARKER, STAMP, /min, mg/R, V, °C, STAMP, /min, %, , °C, STAMP, /min, °BTDC, °BTDC, %
,0.82,861,4.6,1.580,63.0,1.22,861,0.0, 0 1 0,63.0,0.40,861,0.4,0.7,32.7
2.02,861,4.6,1.560,63.0,2.42,861,0.0,0 1 0,63.0,1.62,861,0.4,0.2,35.1
3.22,861,4.6,1.580,63.0,3.62,861,0.0, 0 1 0,63.0,2.82,861,0.4,0.2,33.5
4.42, 861, 4.4, 1.560, 63.0, 4.82, 840, 0.0, 0 1 0, 63.0, 4.02, 861, 0.4, 0.4, 33.1
5.62, 1113, 10.2, 1.760, 63.0, 6.02, 1071, 33.7, 0 0 0, 63.0, 5.22, 1029, 0.2, 0.4, 37.1
6.86, 1197, 17.2, 2.020, 63.0, 7.28, 1680, 48.6, 0 0 0, 63.0, 6.46, 1155, 0.4, 0.2, 34.7
8.10,1680,0.0,0.700,63.0,8.50,1302,37.6,0,0,0,63.0,7.70,2016,0.9,0.0,32.7
9.30,1554,29.0,2.380,63.0,9.70,1848,62.0,0,0,0,63.0,8.90,1386,7.3,5.3,70.1
10.50,2289,27.0,2.440,63.0,10.90,2499,62.0,0,0,0,63.0,10.10,2058,4.4,4.0,43.0
11.72,2982,25.4,2.540,63.0,12.12,2709,0.0, 0 1 0,63.0,11.30,2730,4.6,3.3,55.4
12.92,1953,23.0,2.160,63.0,13.34,2058,63.1, 0 0 0,63.0,12.52,2016,0.7,0.9,23.5
14.14, 2226, 28.2, 2.460, 63.0, 14.54, 2310, 56.5, 0 0 0, 63.0, 13.74, 2142, 5.9, 5.9, 56.2
15.34, 2457, 27.2, 2.540, 63.0, 15.74, 2541, 63.1, 0 0 0, 63.0, 14.94, 2394, 1.8, 1.3, 42.6
16.54,2688,17.8,2.100,63.0,17.00,2709,41.6, 0 0 0,63.0,16.14,2625,3.3,4.0,41.8
17.80,2730,12.6,1.720,63.0,18.20,2730,39.6, 0 0 0,63.0,17.40,2730,0.9,0.4,32.7
19.00,2772,20.6,2.140,63.9,19.40,2814,62.0, 0 0 0,63.9,18.60,2730,1.1,0.4,36.7
20.22, 2961, 25.4, 2.480, 63.9, 20.62, 3045, 61.2, 0, 0, 0, 63.9, 19.82, 2898, 4.0, 4.4, 50.2
21.42,3087,0.0,1.460,63.9,21.82,2373,0.0,0 1 0,63.9,21.02,3108,4.6,5.3,46.6
22.68, 2247, 33.0, 2.700, 63.9, 23.08, 2247, 76.1, 0 0 0, 63.9, 22.28, 2163, 6.6, 5.9, 89.3
23.90, 2352, 33.8, 2.800, 63.9, 24.32, 2415, 76.1, 0 0 0, 64.8, 23.48, 2310, 7.7, 8.1, 55.8
25.14, 2520, 34.2, 2.840, 64.8, 25.54, 2562, 77.3, 0 0 0, 64.8, 24.74, 2457, 8.1, 8.6, 57.8
,26.36,2688,33.8,2.880,64.8,26.76,2730,77.3, 0 0 0,64.8,25.96,2625,8.8,9.5,56.2
27.62, 2856, 38.0, 3.100, 64.8, 28.02, 2919, 90.2, 0, 0, 0, 65.7, 27.22, 2793, 9.9, 10.1, 61.4
28.82,3066,38.6,3.240,65.7,29.22,3129,87.8, 0 0 0,65.7,28.42,2982,10.8,10.8,67.7
'30.04,2835,0.0,0.720,65.7,30.44,2268,42.7, 0 0 0,65.7,29.62,3192,11.7,11.9,66.1'
31.26,2205,34.6,2.820,66.6,31.66,2205,85.1, 0 0 0,66.6,30.86,2184,7.3,5.5,96.4
32.52,2268,38.0,2.900,66.6,32.92,2310,84.7, 0 0 0,66.6,32.06,2247,7.5,8.1,57.4
33.72, 2373, 34.8, 2.900, 67.5, 34.12, 2394, 84.7, 0 0 0, 67.5, 33.32, 2331, 7.7, 7.7, 59.4
34.92,2436,35.6,2.960,67.5,35.32,2478,87.1, 0 0 0,67.5,34.52,2415,7.9,8.6,57.4
36.12,2541,37.6,3.000,67.5,36.52,2583,85.1, 0 0 0,68.4,35.72,2499,8.1,8.4,57.8
37.32, 2646, 37.4, 3.000, 68.4, 37.76, 2667, 84.7, 0, 0, 0, 68.4, 36.92, 2604, 8.8, 8.6, 63.0
38.58, 2730, 41.2, 3.220, 68.4, 38.98, 2772, 100.0, 0, 0, 0, 68.4, 38.16, 2688, 9.5, 9.2, 58.2
39.78, 2835, 39.8, 3.220, 69.3, 40.18, 2856, 100.0, 0 0 0, 69.3, 39.38, 2814, 9.9, 9.7, 60.6
40.98, 2919, 40.8, 3.300, 69.3, 41.38, 2961, 100.0, 0, 0, 0, 69.3, 40.58, 2898, 10.3, 10.6, 63.8
42.18,3003,41.0,3.400,70.2,42.58,3045,100.0, 0 0 0,70.2,41.78,2982,10.8,10.8,63.0
43.42,3024,0.0,0.720,70.2,43.84,2982,0.0,0 1 0,70.2,43.02,3024,0.0,7.3,2.8
44.64,2877,0.0,0.700,70.2,45.04,2814,0.0,0 1 0,71.1,44.24,2940,0.4,0.0,10.8
45.84, 1869, 0.0, 0.700, 71.1, 46.24, 2016, 0.0, 0 1 0, 71.1, 45.44, 2457, 0.9, 0.0, 10.4
47.04,2940,0.0,0.720,71.1,47.44,3339,0.0,0 1 0,71.1,46.64,2541,0.9,0.0,10.0
48.30,3360,0.0,0.720,72.0,48.70,3276,0.0,0 1 0,72.0,47.84,3465,1.5,0.0,13.9
49.52,3087,0.0,0.700,72.0,49.93,3003,0.0,0 1 0,72.0,49.10,3192,0.0,0.0,12.0
50.73, 2835, 0.0, 0.700, 72.0, 51.13, 2751, 0.0, 0 1 0, 72.0, 50.33, 2919, 0.4, 0.0, 10.8
51.93,2562,0.0,0.720,72.0,52.33,2478,0.0,0 1 0,72.0,51.53,2646,0.7,0.0,10.8
,53.19,2310,0.0,0.720,72.0,53.59,2226,0.0, 0 1 0,72.0,52.73,2394,0.9,0.0,9.6
45.39,2079,0.0,0.720,72.0,54.80,2016,0.0,0 1 0,72.0,53.99,2163,0.9,0.0,8.8
,55.61,1911,0.0,0.720,72.0,56.03,1869,0.0, 0 1 0,72.0,55.19,1974,0.9,0.0,8.4
56.86,1827,2.2,1.400,72.9,57.27,1764,0.0, 0 1 0,72.9,56.45,1848,1.3,0.0,9.2
,58.07,882,3.8,1.540,72.9,58.51,924,0.0, 0 1 0,72.9,57.67,1176,0.9,0.0,33.5
,59.31,861,1.6,1.460,72.9,59.71,861,0.0, 0 1 0,72.9,58.91,861,0.4,2.0,26.3
,60.51,861,1.2,1.400,72.9,60.91,861,0.0, 0 1 0,72.9,60.11,861,0.4,0.7,31.5
,61.71,861,1.6,1.420,72.9,62.13,861,0.0, 0 1 0,72.9,61.31,882,0.4,0.4,30.3
,62.95,840,4.0,1.540,72.9,63.35,840,0.0, 0 1 0,72.9,62.53,861,0.4,0.4,30.3
,64.19,861,4.4,1.580,72.9,64.59,861,0.0, 0 1 0,72.9,63.79,840,0.4,0.2,34.3
,65.39,861,4.2,1.620,72.9,65.79,861,0.0, 0 1 0,72.9,64.99,861,0.4,0.2,35.5
,66.59,861,4.2,1.560,72.9,66.99,861,0.0, 0 1 0,72.9,66.19,861,0.4,0.4,34.7
,67.81,861,4.2,1.560,72.9,68.21,861,0.0, 0 1 0,73.8,67.39,861,0.4,0.2,33.5
,69.09,861,4.0,1.540,73.8,69.49,861,0.0, 0 1 0,73.8,68.63,861,0.4,0.4,36.3
,70.29,861,4.4,1.580,73.8,70.69,861,0.0, 0 1 0,73.8,69.89,861,0.4,0.4,33.9
71.49,861,4.4,1.580,73.8,71.89,861,0.0,0,1,0,73.8,71.09,861,0.4,0.4,34.3
,72.69,861,4.2,1.560,73.8,73.09,861,0.0, 0 1 0,73.8,72.29,861,0.4,0.2,35.1
,73.89,861,4.4,1.600,73.8,74.31,861,0.0, 0 1 0,73.8,73.49,861,0.4,0.4,34.7
,75.15,861,4.4,1.580,73.8,75.57,861,0.0, 0 1 0,73.8,74.75,861,0.4,0.4,33.5
,76.37,861,4.4,1.580,73.8,76.77,861,0.0, 0 1 0,73.8,75.97,861,0.4,0.2,34.7
,77.57,861,4.4,1.580,73.8,77.97,861,0.0, 0 1 0,73.8,77.17,861,0.4,0.4,35.5
,78.77,861,4.4,1.580,73.8,79.17,861,0.0, 0 1 0,73.8,78.37,861,0.4,0.7,33.5
,80.01,861,4.6,1.580,73.8,80.41,861,0.0, 0 1 0,73.8,79.57,861,0.4,0.4,33.5
,81.21,861,4.4,1.560,73.8,81.63,861,0.0, 0 1 0,73.8,80.81,861,0.4,0.7,32.7
,82.43,861,4.2,1.580,73.8,82.83,861,0.0, 0 1 0,73.8,82.03,861,0.4,0.4,33.5
,83.63,861,4.4,1.560,73.8,84.03,861,0.0, 0 1 0,73.8,83.23,861,0.4,0.0,36.7
,84.83,861,4.4,1.580,73.8,85.29,861,0.0, 0 1 0,73.8,84.43,861,0.4,0.4,33.9
,86.09,861,4.4,1.580,73.8,86.49,861,0.0, 0 1 0,73.8,85.69,861,0.4,0.2,35.5
,87.31,861,4.2,1.580,73.8,87.71,861,0.0, 0 1 0,73.8,86.89,861,0.4,0.7,34.3
,88.51,861,4.4,1.580,73.8,88.91,861,0.0, 0 1 0,73.8,88.11,861,0.4,0.7,32.7
,89.71,861,4.4,1.560,73.8,90.17,861,0.0, 0 1 0,73.8,89.31,861,0.4,0.2,35.9
,90.97,861,4.4,1.580,73.8,91.37,861,0.0, 0 1 0,73.8,90.57,861,0.4,0.4,35.9
,92.17,861,4.4,1.620,73.8,92.57,861,0.0, 0 1 0,73.8,91.77,861,0.4,0.2,33.1
,93.39,861,4.4,1.600,73.8,93.79,861,0.0, 0 1 0,73.8,92.97,861,0.4,0.4,33.9
,94.61,861,4.2,1.560,73.8,95.01,861,0.0, 0 1 0,73.8,94.21,861,0.4,0.4,33.9
,95.87,861,4.4,1.560,73.8,96.27,861,0.0, 0 1 0,73.8,95.41,861,0.4,0.2,34.3
,97.07,861,4.4,1.580,73.8,97.47,861,0.0, 0 1 0,73.8,96.67,861,0.4,0.7,35.1
,98.27,861,4.4,1.580,73.8,98.67,861,0.0, 0 1 0,73.8,97.87,861,0.4,0.4,33.9
,99.47,861,4.4,1.580,73.8,99.89,861,0.0, 0 1 0,73.8,99.07,861,0.4,0.7,33.1
100.69,861,4.4,1.580,73.8,101.14,861,0.0, 0 1 0,73.8,100.29,861,0.4,0.4,34.3
,101.94,861,4.6,1.600,73.8,102.34,861,0.0, 0 1 0,73.8,101.54,861,0.4,0.4,35.1
,103.15,945,11.6,1.860,73.8,103.55,1113,27.5, 0 0 0,73.8,102.74,861,0.4,0.4,35.1
,104.35,1344,17.4,1.940,73.8,104.75,1533,42.7, 0 0 0,73.8,103.95,1176,0.2,0.0,30.7
105.55, 2016, 0.0, 0.700, 73.8, 105.95, 1428, 19.6, 0, 1, 0, 73.8, 105.15, 1911, 0.4, 2.2, 27.5
106.79,1533,21.0,2.080,73.8,107.19,1701,49.0, 0 0 0,73.8,106.35,1386,0.9,0.4,23.5
108.01,2058,15.6,1.920,73.8,108.41,2184,41.2,0,0,0,73.8,107.61,1911,0.4,0.9,29.9
109.21,2415,11.0,1.700,73.8,109.60,1974,0.0, 0 1 0,73.8,108.80,2310,0.4,1.1,30.7
,110.41,1575,20.4,2.020,73.8,110.81,1659,58.0, 0 0 0,73.8,110.01,1470,1.3,0.4,2.8
,111.60,1869,28.8,2.460,73.8,112.01,1995,67.1, 0 0 0,73.8,111.20,1764,3.5,4.0,45.0
112.87,2289,33.0,2.760,73.8,113.29,2436,75.7, 0 0 0,73.8,112.46,2163,7.3,7.7,59.4
114.10, 2709, 32.6, 2.840, 73.8, 114.50, 2856, 73.7, 0, 0, 0, 73.8, 113.70, 2562, 8.6, 8.8, 57.4
115.30,2205,1.0,0.720,73.8,115.71,2058,55.7, 0 0 0,73.8,114.90,2835,0.2,6.6,2.8
,116.50,2121,25.0,2.340,73.8,116.91,2163,57.3, 0 0 0,73.8,116.10,2100,1.1,1.3,39.0
,117.74,2247,23.2,2.280,74.7,118.14,2268,49.4, 0 0 0,74.7,117.30,2205,1.1,1.1,39.0
,118.99,2331,18.4,2.080,74.7,119.40,2373,51.4, 0 0 0,74.7,118.56,2310,0.0,0.2,33.5
,120.20,2415,22.0,2.300,74.7,120.61,2457,55.3, 0 0 0,74.7,119.80,2394,0.4,0.0,36.7
121.40,2520,23.8,2.340,74.7,121.80,2541,58.4, 0 0 0,74.7,121.00,2478,1.1,0.9,40.2
122.60,2625,23.2,2.360,75.6,123.00,2667,51.8, 0 0 0,75.6,122.20,2604,2.4,2.4,41.8
123.84,2709,19.0,2.100,75.6,124.24,2709,50.2, 0 0 0,75.6,123.44,2688,1.1,1.1,37.5
125.08,2751,20.4,2.200,75.6,125.48,2793,54.5, 0 0 0,75.6,124.66,2730,1.3,1.1,37.9
126.28, 2835, 21.4, 2.220, 75.6, 126.68, 2856, 60.4, 0 0 0, 75.6, 125.88, 2814, 2.0, 2.2, 39.8
127.48, 2961, 41.0, 3.320, 75.6, 127.88, 3045, 100.0, 0, 0, 0, 75.6, 127.08, 2898, 10.3, 12.5, 48.2
128.74,3171,38.6,3.300,76.5,129.14,3213,100.0, 0 0 0,76.5,128.28,3087,11.2,11.4,64.5
129.94,3360,38.2,3.340,76.5,130.34,3423,100.0, 0 0 0,76.5,129.54,3297,12.1,12.5,65.7
,131.18,3528,38.2,3.360,76.5,131.60,3612,100.0, 0 0 0,76.5,130.76,3486,13.0,12.8,65.3
132.40,2982,0.0,0.720,77.4,132.80,2436,59.6, 0 0 0,77.4,132.00,3675,14.1,14.3,69.7
133.60,2478,41.2,3.160,77.4,134.04,2520,100.0, 0 0 0,77.4,133.20,2457,8.1,9.5,59.0
134.84,2562,34.4,2.940,77.4,135.24,2583,100.0, 0 0 0,78.3,134.44,2541,8.4,8.1,62.6
136.04,2625,41.2,3.240,78.3,136.44,2646,100.0, 0 0 0,78.3,135.64,2583,8.8,9.0,58.2
137.24,2688,34.0,2.900,78.3,137.66,2688,100.0, 0 0 0,78.3,136.84,2667,9.2,8.8,58.2
138.46,2751,41.2,3.220,79.2,138.86,2751,100.0, 0 0 0,79.2,138.06,2730,9.5,9.9,60.6
,139.72,2814,34.6,2.960,79.2,140.12,2814,100.0, 0 0 0,79.2,139.32,2793,9.9,9.7,58.6
140.92,2856,41.2,3.300,80.1,141.32,2877,100.0, 0 0 0,80.1,140.52,2835,10.1,10.6,60.2
142.12,2877,12.2,2.240,80.1,142.52,2898,0.0, 0 1 0,80.1,141.72,2898,10.3,10.6,65.3
143.34,2793,0.0,0.700,80.1,143.76,2772,0.0,0 1 0,81.0,142.92,2793,0.4,0.0,10.8
144.56,2772,23.8,2.420,81.0,144.96,2730,100.0, 0 0 0,81.0,144.16,2730,0.4,0.0,11.2
145.76,2751,41.2,3.240,81.0,146.22,2772,100.0, 0 0 0,81.0,145.36,2730,9.7,9.9,57.8
147.02, 2814, 41.2, 3.260, 81.9, 147.42, 2835, 100.0, 0, 0, 0, 81.9, 146.62, 2793, 9.9, 11.0, 62.6
148.22, 2856, 34.2, 2.960, 81.9, 148.62, 2877, 90.6, 0, 0, 0, 81.9, 147.82, 2856, 10.1, 10.1, 64.5
149.44,2919,40.0,3.280,81.9,149.86,2940,100.0, 0 0 0,81.9,149.02,2898,10.3,10.3,60.6
,150.66,2982,39.2,3.320,82.8,151.08,2982,100.0, 0 0 0,82.8,150.26,2961,10.6,10.3,59.4
151.94,3024,37.4,3.180,82.8,152.38,3045,100.0, 0 0 0,82.8,151.50,3003,10.8,11.2,61.0
153.18,3087,37.2,3.220,82.8,153.58,3108,100.0, 0 0 0,83.7,152.78,3066,11.2,11.2,61.0
154.38,3129,38.0,3.300,83.7,154.78,3150,100.0, 0 0 0,83.7,153.98,3129,11.4,11.2,62.2
155.62,3192,37.2,3.240,83.7,156.02,3192,100.0, 0 0 0,83.7,155.22,3171,11.7,11.2,64.1
156.84,3234,36.4,3.200,83.7,157.24,3255,100.0, 0 0 0,84.6,156.42,3213,11.9,12.1,62.6
158.04,3276,37.0,3.240,84.6,158.44,3276,100.0, 0 0 0,84.6,157.64,3255,12.1,12.1,64.5
159.24,3318,36.4,3.260,84.6,159.64,3318,100.0, 0 0 0,84.6,158.84,3297,12.1,12.1,62.6
,160.48,3339,38.0,3.280,84.6,160.88,3339,100.0, 0 0 0,84.6,160.04,3318,12.3,12.1,64.5
161.68,3381,36.2,3.300,84.6,162.08,3381,100.0, 0 0 0,84.6,161.28,3360,12.5,12.8,65.7
162.90,3402,36.8,3.300,84.6,163.30,3402,100.0, 0 0 0,84.6,162.48,3381,12.5,12.1,69.3
164.16,3423,37.0,3.320,84.6,164.56,3444,100.0, 0 0 0,84.6,163.76,3423,12.8,12.8,63.4
165.36,3465,36.8,3.260,84.6,165.76,3465,100.0, 0 0 0,85.5,164.96,3444,13.0,13.4,64.9
166.56,3465,37.4,3.340,85.5,166.96,3486,89.0, 0 0 0,85.5,166.16,3465,13.0,13.0,64.9
,167.76,3402,0.0,1.160,85.5,168.22,3381,0.0, 0 1 0,85.5,167.36,3465,3.7,7.0,2.8
169.02,3297,0.0,0.720,85.5,169.43,3234,0.0,0 1 0,85.5,168.62,3318,1.5,0.0,13.1
170.24,3171,0.0,0.720,85.5,170.69,3129,0.0,0 1 0,85.5,169.83,3213,1.1,0.0,12.4
171.49,3045,0.0,0.720,85.5,171.89,3003,0.0,0 1 0,85.5,171.09,3087,0.4,0.0,11.2
172.69,2940,0.0,0.700,85.5,173.10,2898,0.0,0 1 0,85.5,172.29,2961,0.0,0.0,10.4
173.95,2814,0.0,0.720,84.6,174.36,2793,0.0,0 1 0,84.6,173.55,2856,0.2,0.0,10.8
,175.18,2730,0.0,0.700,84.6,175.59,2688,0.0, 0 1 0,84.6,174.77,2751,0.4,0.0,11.2
176.40,2625,0.0,0.720,84.6,176.83,2604,0.0,0 1 0,84.6,175.99,2667,0.7,0.0,10.8
177.63,2541,0.0,0.700,84.6,178.03,2520,0.0,0 1 0,84.6,177.23,2562,0.9,0.0,10.4
178.83,2520,11.4,1.580,84.6,179.23,2478,58.0, 0 0 0,84.6,178.43,2478,0.9,0.0,10.0
,180.04,2499,29.0,2.640,84.6,180.49,2520,100.0, 0 0 0,84.6,179.63,2478,5.1,4.0,56.6
181.30,2583,41.2,3.240,83.7,181.70,2604,100.0, 0 0 0,83.7,180.90,2562,8.6,9.0,60.2
182.51,2667,33.0,2.840,83.7,182.91,2688,100.0, 0 0 0,83.7,182.11,2646,9.0,9.0,57.0
183.75, 2709, 35.2, 3.060, 83.7, 184.15, 2709, 45.9, 0 0 0, 83.7, 183.31, 2688, 9.5, 9.7, 60.2
184.95,2688,5.2,1.440,83.7,185.35,2688,17.3,0,0,0,83.7,184.55,2709,0.4,1.1,21.9
186.17,2625,0.0,0.700,83.7,186.57,2604,0.0,0 1 0,83.7,185.77,2646,0.7,0.0,10.8
187.39,2541,0.0,0.720,83.7,187.83,2520,0.0,0 1 0,83.7,186.97,2583,0.9,0.0,10.4
188.63,2478,2.8,1.400,83.7,189.03,2478,25.9, 0 0 0,83.7,188.23,2499,0.9,0.0,10.0
189.83,2436,10.8,1.760,83.7,190.23,2436,40.0, 0 0 0,83.7,189.43,2457,0.9,0.7,27.5
191.03,2436,15.8,1.960,83.7,191.43,2415,40.0,0,0,0,83.7,190.63,2436,0.0,0.0,35.1
192.27,2394,8.6,1.560,83.7,192.67,2394,29.0, 0 0 0,83.7,191.87,2415,0.9,0.7,29.1
193.47,2373,8.2,1.540,83.7,193.87,2310,9.4, 0 0 0,83.7,193.07,2373,0.9,0.9,26.7
194.69,2310,0.0,0.720,83.7,195.15,2289,0.0,0 1 0,83.7,194.27,2331,0.9,0.0,10.0
195.95,2226,0.0,0.700,83.7,196.35,2205,0.0,0 1 0,83.7,195.55,2268,0.9,0.0,9.2
197.15,2163,0.0,0.720,83.7,197.55,2142,0.0,0 1 0,83.7,196.75,2184,0.9,0.0,9.2
Translated on 15-08-2026, 0:47.
Jochen_145
Post26-11-2007, 0:54    Subject: Uneven Performance: Causes and Solutions Quote
I'm sure no one will want to deal with this mess of numbers.
Please just upload the log file as a file here so that we can better review it and create graphs.
For quick previews, there are now great tools available from RKS icon_wink.gif.
Best regards, Jochen.
Translated on 15-08-2026, 0:48.
oschoppm
Post26-11-2007, 17:11    Subject: Best German Translation Services - Affordable & Fast Quote
I have the file here http://www.feine-busse.de/LOG-01-001-002-005.CSV.
Thank you in advance!
Translated on 15-08-2026, 0:49.
Post26-11-2007, 20:42    Subject: Uneven Performance: Causes and Solutions Quote
That's not better either.
Please read the instructions, import the data into Excel, and analyze it graphically. It's not a problem. No one here can make sense of this mess of numbers... sorry.
Jochen_145
Post27-11-2007, 12:50    Subject: Uneven Performance: Causes and Solutions Quote
Okay, I quickly looked over the data.
The injection molding machine is working properly according to IMA standards.
What I don't like at all is the amount of fuel being injected. It fluctuates wildly and reinforces your impression of the inconsistent performance.
Could it be that your air mass or the LD (likely referring to a specific data point or parameter) is not appropriate, or that one of them is exhibiting wave-like behavior?
Then you would have an explanation for the fluctuations in your fuel injection amount.
You're going under the smoke barrier.
Please generate a log file with the following identifiers: MWB 003-008-011.
Translated on 15-08-2026, 0:50.
Post27-11-2007, 13:47    Subject: Uneven Performance: Causes and Solutions Quote
Jochen_145 wrote:
Perform a MWB 003-008-011
... but also include partial load fluctuations with less than half throttle: this shows whether the EGR system is working correctly, or if it might cause problems at full throttle due to sticking.
Without partial load passages, the MWB3 is just a useless sample rate limiter; in that case, it's better to use 008-010 or 008-011 icon_wink.gif.
Translated on 15-08-2026, 0:52.
oschoppm
Post01-12-2007, 21:19    Subject: Management Still Bad? Find Out Now! Quote
Well, I had a mechanic who claimed to be an expert look at it. He couldn't find anything during a test drive. Then we talked about fuel pressure and other things, and just to be on the safe side, I replaced the fuel filter, the return valve, and some of the fuel hoses...of course, that didn't solve the problem.
However, I bought a turbocharger from eBay (item number 260144214968), which seemed strange to me, but it was cheap...
He was 9 months old and externally only had a sheared stud... I suspect it might be that one. I will do the measurement run soon. Should I take the measurements while accelerating?
By the way, I disconnected the EGR valve (by blocking the hose).
Can the engine be damaged? I have to transport a bus with it on Tuesday!
I'm also planning to separate the CAT (presumably a catalytic converter) because my vehicle is a truck. Can I expect any issues with that?
I've already tried swapping the LMM (likely referring to a lambda manifold module), but I couldn't detect any difference.
Translated on 15-08-2026, 0:54.
Jochen_145
Post02-12-2007, 11:34    Subject: Slow Internet Connection Still? Get Help Now! Quote
I bought a turbocharger from eBay (listing number 260144214968), which seemed strange to me, but it was cheap...
He was 9 months old and externally only had a torn stud bolt... I suspect it might be that one. I will soon perform the measurement run. Should I take the measurement while accelerating?
Yes, please conduct the required measurement run both at full load and at partial load.
Could it be that your air mass or the LD (likely referring to a specific data point or layer) is not appropriate, or that one of them is wavy?
You are jumping under the smoke barrier .
This seems like a perfect fit for a faulty turbocharger. The test drive should provide further insights.
Translated on 15-08-2026, 0:57.
No new posts Schwache Leistung==> nicht LLM! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ab und zu keine Leistung TDI Diesel Engine Technology
No new posts A6 4b 2,5 TDI keine Leistung On-Board Diagnostics (OBD)
No new posts AEL: More Power & Performance Diesel Engine Technology
No new posts A6 C5 2,5 V6 TDI No power output from 3.000 rpm Diesel Engine Technology
