Pinout diagram for 1.7 SDI engine control unit
rasmus_th
Post08-12-2007, 19:17    Subject: Pinout diagram for 1.7 SDI engine control unit Quote
Hello everyone,
Today, I installed a GRA steering column lever in my VW Polo 1.7 SDI Variant (engine code: AKW). Unfortunately, I was unable to connect it because this car doesn't have a free connector for it from the factory.
Now, I have a question: Does anyone know the pinout for the motor controller?
I could directly wire the lever to the control unit.
Here are the detailed specifications for the control unit:
VAG Number: 038 906 013J
1.7L R4EDC G20SG 1826
I would be extremely GRATEFUL icon_cool.gif for help.
Rasmus.
Translated on 05-07-2026, 17:34.
rasmus_th
Post09-12-2007, 13:01    Subject: Pinout diagram for 1.7 SDI engine control unit Quote
Does anyone have the pinout for this?
Translated on 05-07-2026, 17:35.
Post09-12-2007, 15:41    Subject: Pinout diagram for 1.7 SDI engine control unit Quote
Complaining doesn't help.
Do you have a picture of the part?
I _suspect_ that the layout is the same as it was for the "same-age" TDIs.
Okay, so if the part has the two-piece connector, I would look up the pinout for TDIs with two-piece connectors. If it's the old, one-piece connector, then I would refer to the pinout for that.
This portal contains all sorts of information.
http://volkswagen.msk.ru/
rasmus_th
Post09-12-2007, 17:56    Subject: Pinout diagram for 1.7 SDI engine control unit Quote
It's a 2-part plug. Thank you for the address, but I'm having trouble navigating the website. When I look at the TDIs, there are many different wiring diagrams.
I'm not really making any progress.
Translated on 05-07-2026, 17:36.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.löschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KST 1J0 959 799 Pinout: Connector Diagram & Info On-Board Diagnostics (OBD)
No new posts Pinbelegung MSG 184Nm 1Z On-Board Diagnostics (OBD)
No new posts ECU Pinout: Find Connector Pin Assignments On-Board Diagnostics (OBD)
No new posts ESP Pinout Audi 80 TDI Diesel Engine Technology
