Webasto ThermoTop: Diagnostic Software & Error Codes
freeze_alert
Post24-01-2007, 17:17    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
Can someone please help me?
I need software to read and, if necessary, clear the error codes from my ThermoTop.
Thank you very much.
Tommy.
Translated on 24-10-2026, 8:16.
Maxx1278
Avatar-Maxx1278
Post25-01-2007, 8:54    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
Hello!
Google recommends this to you:
http://www.techwebasto.com/thermosystems_thermo_test.htm
Best regards.
Maxx.
Translated on 24-10-2026, 8:17.
freeze_alert
Post25-01-2007, 14:39    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
Thank you.
But I was told that you can't read or clear error codes with it!
Malte1408
Karma: +12 / -0   Thank you, like it!
Post26-01-2007, 11:33    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
And I'm telling you that you can do things with it.
Do you have an auxiliary heater that was installed later, or did it come with the car from the factory?
megaonkel
Post29-01-2007, 18:01    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
Even though this might be a repost, but: Is it possible to change the temperature setting that is always targeted in the interior when using the SH (standing heating) function of a (factory-installed) SH system, using this Webasto software or another software?
"Thank you."
Translated on 24-10-2026, 8:18.
freeze_alert
Post29-01-2007, 19:44    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
It's an aftermarket Webasto unit.
Okay, then I'll try to see if this works icon_smile.gif.
Thank you for the information...
Translated on 24-10-2026, 8:19.
christians
Post12-12-2007, 12:50    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
To the best of my knowledge, the old software had issues with optocouplers. If you drive a VAG vehicle, I would suggest first trying to access a different control unit using VAG-COM for testing purposes.
Gruß Christian
wolfi_b
Post13-12-2007, 8:04    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
christians wrote:
As far as I am aware, the old software had problems with optocouplers.
"That's also my experience. ThermoTest doesn't work with Opto-Adapters. However, there was a DOS version (with a smaller set of features) that did work with Opto-Adapters!"
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 24-10-2026, 8:20.
Post13-12-2007, 11:38    Subject: Webasto ThermoTop: Diagnostic Software & Error Codes Quote
Okay, I'm ready. Please provide the German text you want me to translate.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts ThermoTop V: Unexplained Error Troubleshooting On-Board Diagnostics (OBD)
No new posts Error memory 1Z-TDI Diesel Engine Technology
No new posts Software for BMW? On-Board Diagnostics (OBD)
No new posts Clear Error Codes: How-To Guide Diesel Engine Technology
