Car Door Panel Clips: Install & Remove
Post19-11-2007, 13:19    Subject: Car Door Panel Clips: Install & Remove Quote
Are there already any "long-term experiences" on how the original VW wheel center caps hold up when they are repeatedly removed from the aluminum rims every autumn to allow the rims to fit on the wheel balancer, and then reattached in the spring?
Translated on 07-10-2026, 19:25.
limpi
Post19-11-2007, 16:55    Subject: Car Door Panel Clips: Install & Remove Quote
Okay, I have long-term experience with Skoda hubcaps. They should be the same. The quality has been very good so far, and I've never had any problems. They withstand repeated clipping on and off without issues for a long time. Just don't use excessive force.
Best regards, Limpi.
Translated on 07-10-2026, 19:26.
oldewurtel
Post24-12-2007, 18:16    Subject: Car Door Panel Clips: Install & Remove Quote
Hello Martin,
I once damaged a lid on one of my 5-star aluminum containers when I pushed it out at an angle with my hand in COLD weather.
That thing cost about 14 DM back then icon_twisted.gif !!
Best regards, Kassen.
