Outdoor Temperature Sensor
brezelmann01
Post22-12-2002, 17:24    Subject: Outdoor Temperature Sensor Quote
Hi!
I have a question for those who have worked with the speedometer of a 6NF GTI. Which pins are connected to the outside temperature sensor? And what are the wire colors associated with those pins?
Oh yes, then I'd also like to know where the sensor is located. Is it mounted at the front of the bumper?
Thank you for your help!
brezelmann01
Translated on 16-10-2026, 15:50.
TDI-Fahrer
Post24-12-2002, 2:49    Subject: Antennas: How They Work and Their Uses Quote
The sensor should be located between the bumper and the radiator. It is usually attached to a plastic bracket on the oil cooler.
Translated on 16-10-2026, 15:51.
