Dalitroll Guest
11-09-2002, 21:41 Subject: Side Airbag Malfunction: Loose Connection? |
Dear members,
The airbag warning light is on in my car. The diagnostic tool shows a 'resistance to high' error for the left-side airbag.
The Volkswagen dealer says that the actual passenger airbag and the wiring harness need to be replaced. However, in American forums, I've read that it's often just a loose connection in the cable for the Golf IV.
How can I check that?
Three cables connect to the side airbag: a yellow/blue cable, a yellow/green cable, and a brown cable. What is the purpose of the brown cable?
Can I simulate a certain resistance value to the airbag control unit for troubleshooting purposes? I've heard that this can be done with a 26-ohm resistor?
-Is that correct?
Where are all the connectors located? I only found one under the seat – are there any others?
Where is the control unit located?
Thank you very much.
and best regards,
Translated on 24-07-2026, 14:02.
H-P Guest
12-09-2002, 19:31 Subject: Side Airbag Malfunction: Loose Connection? |
It happened with my '97 A4 Avant too.
My instructor said to cut the wires at the plug and then...
to directly solder them together.
Done and said by self-made: Then off to the workshop to fix the problem.
'Have the memory erased. The error has not occurred since then.'
stepped on.
Best regards, H-P.
Translated on 24-07-2026, 14:04.
GOLFTDI Guest
26-12-2002, 16:03 Subject: Side Airbag Malfunction: Loose Connection? |
Does this also apply to the front passenger airbag of the VW Golf IV?
Translated on 24-07-2026, 14:05.
