SDI Injection Pump: Repair & Replacement
Kopi
Post22-01-2008, 16:50    Subject: SDI Injection Pump: Repair & Replacement Quote
Hello.
I'm still having the problem of converting the SDI injection pump from a 2004 Polomotor engine that I want to marineize from electronic to mechanical. I had it sent in for conversion, but now it's being returned because the conversion isn't working; the mechanical parts apparently don't fit inside the housing.
Does anyone have any other suggestions for what I could do?
Best regards, Kopi.
Translated on 22-09-2026, 18:25.
Back to top Profile PM Email
kuestenkuddel
Post23-01-2008, 21:12    Subject: SDI Injection Pump: Repair & Replacement Quote
Hello Kopi.
The internal components of mechanical ESPs won't fit inside your enclosure, so you can forget about that option.
If I were in your shoes, I would try to get an old ESP, perhaps from a Golf, to work with the engine.
Perhaps your 'important parts,' such as the impeller and high-pressure component, will fit.
Best regards, Kurt.
Translated on 22-09-2026, 18:26.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 Injection Pump Diesel Engine Technology
No new posts CAV Injection Pump Diesel Engine Technology
No new posts Fuel Injector AFN Diesel Engine Technology
No new posts SDI Fuel Injector: Performance & Reliability On-Board Diagnostics (OBD)
