It should work on Audi vehicles at least when the outside temperature is below 6°C, econ mode is turned off, and the generator load is not too high, I think less than 60%, but I need to double-check that.
I'm not sure when mine actually starts heating up either. Most of the time, the auxiliary heater is already running, and in the early morning, I don't have the time or inclination to check it using VAG-Com.
Gruß Christian
Translated on 21-10-2026, 8:14.
