Activate auxiliary heater?
Post28-01-2008, 16:17    Subject: Activate auxiliary heater? Quote
Hi.
"For some time now, TDIs (and likely other engines) have no longer been 'heated' using glow plugs in the coolant, but directly via 'glow wires' in the airflow of the heating system."
How can I activate them?
Because:
If I simply leave the Climatronic (CT) running, it doesn't overheat, even when the outside temperature is below freezing and the desired indoor temperature is 20 degrees Celsius.
The "Defrost" program activates the heater, and even an immediate switch to Auto/Eco mode will leave it running.
Is "Auto-defrost-Auto" the "official" and only variant?
Can I turn this feature off again?
Okay, here's the translation:
Thank you.
Translated on 21-10-2026, 8:12.
christians
Post28-01-2008, 16:21    Subject: Activate auxiliary heater? Quote
It should work on Audi vehicles at least when the outside temperature is below 6°C, econ mode is turned off, and the generator load is not too high, I think less than 60%, but I need to double-check that.
I'm not sure when mine actually starts heating up either. Most of the time, the auxiliary heater is already running, and in the early morning, I don't have the time or inclination to check it using VAG-Com.
Gruß Christian
Translated on 21-10-2026, 8:14.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Activate GRA: How to Enable & Use Diesel Engine Technology
No new posts Activate GRA in Audi A2 Diesel Engine Technology
No new posts Enable Comfort Blinking On-Board Diagnostics (OBD)
No new posts CAN Bus Activation Seat 1.9 TDI ASV On-Board Diagnostics (OBD)
