bastianna Blaumann
Joined: 06/22/2004 Posts: 74 Karma: +6 / -0 Location: Fränkisches Seenland
28-01-2008, 13:44 Subject: T4 engine cut out while driving, and... |
Hello fellow mechanics,
Vehicle: VW T4 TDI with ACV engine. It suddenly stopped working while driving on a country road and won't start anymore.
Relay 109 replaced, shut-off valve checked for functionality, and it is working correctly.
The power supply to the shut-off valve is initially active when the ignition is turned on. After approximately 1 minute, the power supply cuts off, and after another minute, the preheating lamp starts flashing.
Unfortunately, I don't have a VAG-Com device, and the vehicle is currently in my yard after being towed here. This means that the error memory has not been read yet.
I've already searched the forum, does anyone have any advice for me?
bastiana
Das Leben ist schön, wenn man es lebt.
Translated on 21-07-2026, 18:10.
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
28-01-2008, 13:57 Subject: T4 engine cut out while driving, and... |
Basically, it will be difficult without knowing the error codes stored in the system's memory.
Is it related to the relay number 109? Because after that minute, there's still voltage present, and then the voltage disappears.
It could be from an ESP STG source, but it could also come from many other sources.
Translated on 21-07-2026, 18:12.
bastianna Blaumann
28-01-2008, 18:39 Subject: T4 engine cut out while driving, and... |
I couldn't figure it out, so I went to the helpful (but slow) person.
Diagnosis: Faulty fuel injection pump, specifically the metering unit. There is a 7-pin connector here, and the resistance between pin 5 and 6 should be measured; the value should be between 0.5 and 2.5 ohms. The measurement result was zero, indicating no contact!
So, there's no mechanical problem.
Repair costs: €1750.
Okay, so what now? Can I repair this thing?
Best regards, Bastianna.
Translated on 21-07-2026, 18:13.
Boro Guest
07-02-2008, 8:24 Subject: T4 engine cut out while driving, and... |
Possibly, there is only a cable break at the connectors! This happens more often and is easy to fix! So, first check all the cables at the connector of the pump and also the corresponding connector  .
Translated on 21-07-2026, 18:14.
bastianna Blaumann
08-02-2008, 13:59 Subject: T4 engine cut out while driving, and... |
Hey everyone,
Pump it up, TOD!
Bill amount at the service center: €2003.41.
Thank you for your contributions.
Translated on 21-07-2026, 18:15.
cksIT Blaumann
08-02-2008, 22:01 Subject: T4 engine cut out while driving, and... |
Ouch, that's quite bad...
Fortunately, I was able to do it myself, which made it relatively "cheap" for my brother.
I can't make anything of this engine. When I compare it to mine, I get a better price and even have slightly more power... (and mine has significantly more mileage).
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
10-02-2008, 17:36 Subject: T4 engine cut out while driving, and... |
bastianna wrote: | Hi everyone,
Pump it up, TOD!
Thank you for your contributions | .
That was expensive; for our  , the whole thing cost 1400 euros, including materials and labor. It was an ACV from 04/1996.
He probably needed new panes of glass for the glass palace  .
Best regards, Rüdi.
P.S. Where does the €250 difference in the cost of living allowance actually come from?
Translated on 21-07-2026, 18:17.
Profile PM Garage |
