Passat Idle Problem: AVB Engine Fix
bartheho
Post13-08-2009, 20:26    Subject: Passat Idle Problem: AVB Engine Fix Quote
I hope for your help.
Our family car has been making an uneven idling sound since early this morning, and it's a mystery to me.
- Year of manufacture: 2005, mileage: approximately 40,000 km, no chip tuning or modifications.
- No error codes found in the fault memory.
"When the engine idles for a longer period, the uneven running becomes much more noticeable. I've checked the intercooler, as far as I could with a cable lamp outside, and haven't found anything. What I did notice was a kind of oil sludge, or something similar, a black, viscous goo, which I found at the separation point between the engine and the transmission, in the direction of view below the oil filter. It's a very thick, dark black substance, which is unusual for an otherwise clean engine. As I mentioned, it's located between the oil filter and the fuel filter, in the direction of the transmission."
I once tried to take a picture of it, and I hope I can upload it...
I am grateful for any suggestions.
Best regards, Holger.
 File size:  51.93 KB
 Viewed:  5429 times
Passat Bj. 2014, MKB CAYC
Translated on 28-09-2026, 2:04.
Post13-08-2009, 20:35    Subject: Passat Idle Problem: AVB Engine Fix Quote
I would say it's a disgusting bird. It's just DISGUSTING icon_lol.gif.
Wash your car sometime and don't drive so fast.
If it came out from under the clutch bell housing, it's likely the dual-mass flywheel (DMF) friction material. -> A faulty DMF is the cause of the jerking.
Translated on 28-09-2026, 2:06.
bartheho
Post13-08-2009, 20:37    Subject: Passat Idle Problem: AVB Engine Fix Quote
Hello Reiner,
No, it's a type of oily sludge, almost like graphite...
Post13-08-2009, 20:38    Subject: Passat Idle Problem: AVB Engine Fix Quote
It was just meant to be funny. I've edited my post above.
Translated on 28-09-2026, 2:07.
bartheho
Post13-08-2009, 20:50    Subject: Passat Idle Problem: AVB Engine Fix Quote
Sorry, but I was expecting this, and I'm a bit annoyed. I'm going to visit a friend tomorrow who runs a good independent garage, and I'll let you know what he says.
Does VW still offer goodwill guarantees for vehicles manufactured in 2005?
bartheho
Post14-08-2009, 8:06    Subject: SEO: Best Practices for Keyword Ranking Quote
I went to VW, and they confirmed the diagnosis. VW will cover 50% of the material and labor costs.
Translated on 28-09-2026, 2:08.
haithamina
Post14-08-2009, 12:59    Subject: Passat Idle Problem: AVB Engine Fix Quote
I honestly wouldn't have expected that kind of response and sense of responsibility from those men! Let's raise a glass together and celebrate properly! It doesn't happen every day that you get a pleasant surprise.
Glad to hear it, bartheho.
bartheho
Post14-08-2009, 20:29    Subject: Passat Idle Problem: AVB Engine Fix Quote
http://www.autoteile-pirna.com/infos/07-11/LUK_ZMS_Broschuere_Technik.pdf
I found it very helpful.
Translated on 28-09-2026, 2:09.
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rough Idle 2.5 V6 TDI BDG Engine Diesel Engine Technology
No new posts 1.9 TDI: Intermittent Idle Issues & Fixes On-Board Diagnostics (OBD)
No new posts Ford TDDI: Rough Idle & Troubleshooting Diesel Engine Technology
No new posts Engine Misfire? Diagnose OK, but Performance Issues. Diesel Engine Technology
