Combine two Webasto's into one?
grünling
Post17-02-2008, 14:30    Subject: Combine two Webasto's into one? Quote
Hello everyone,
I'm new to this forum and would like to take advantage of this opportunity to ask a question.
My previous Webasto Top C (Diesel) has broken down. A friend of mine used a diagnostic tool to read the following error message:
NAK: Unknown negative acknowledgement code 0x45 or solenoid failure code 90
What do these error codes mean?
I would like to convert two Webasto (diesel) units into one, and I am now wondering if these units can be interchanged with each other (e.g., with a Webasto Top C/Z or E).
Do the differences generally only lie in the control software (i.e., only replacing the control unit)? Or are there also different types of glow plugs and combustion chambers, etc.?
I also read that there are TT models with 4.2 kW or 5.0 kW.
I would appreciate a response.
Best regards from the Lusatia region.
Greenling
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Replace Fuel Injectors: DIY Guide & Tips Diesel Engine Technology
No new posts OM 948.961: Preparing for the East Diesel Engine Technology
No new posts Golf 4: How to Enable/Disable ABS? On-Board Diagnostics (OBD)
No new posts Jet Tuning: American Style for Performance Cars. Diesel Engine Technology
