Polo MK4 AC Noise: Diagnosis & Repair Guide (Solution)
Michael II
Post30-12-2002, 16:17    Subject: Polo MK4 AC Noise: Diagnosis & Repair Guide Quote
Mitsubishi Polo MJ 2002: Noise may occur when the air conditioning is turned on.
Affected vehicle identification numbers (VINs):
Bis Fg. No. 9N 3Y 090 000
Bis Fg. No. 9N 3D 070 000
Definition:
These are described as whining or wind-like noises, or also as the operating noise of the pump for the power steering system.
Cause.
If the hissing sound after turning off the air conditioner is no longer audible, then the expansion valve may be the cause. During the calibration of the expansion valve, there were tolerances that were too large.
Solution.
In case of a defect, please install an expansion valve with part number 6Q0 820 679 A.
Tschüss
Michael II
Translated on 17-08-2026, 11:46.
Ratings - Polo MK4 AC Noise: Diagnosis & Repair Guide
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Doku: Door Lock Noises - MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Air Conditioning Fault 1206 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Noises Golf 4: Troubleshooting & Repair Transmission, Chassis, Body & Interior
No new posts VAG-COM: No Central Locking on Polo 1.4 TDI (2002) On-Board Diagnostics (OBD)
No new posts Blubber Sounds: What Causes Them? Diesel Engine Technology
No new posts Sounds of A4 driver's door Transmission, Chassis, Body & Interior
