Doku Polo MJ 2002, Gearbox noises (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post30-12-2002, 17:20    Subject: Doku Polo MJ 2002, Gearbox noises Quote
Polo MJ 2002
A noise, similar to rattling gears, is coming from the gearbox and disappears when the clutch pedal is depressed. The noise, with varying intensity, is audible in the left wheel well.
The noise is also audible in the 1st and 2nd gear under load at approximately < 1,000/min and during downhill driving.
Cause:
Tolerances in the gearbox.
VAG's proposed solution:
Avoid repair if possible!
The noise has no effect on the function and lifespan of the gearbox.
Please only contact your product support in the case of persistent complaints.
TschĂŒss
Michael II
Ratings - Doku Polo MJ 2002, Gearbox noises
No new posts Doku Polo MJ 2002, GerÀusche aus Klimaanlage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2002, GerĂ€usche aus TĂŒrschlössern Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, Keine LenkunterstĂŒtzung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG COM findet ZV bei Polo 1,4 TDI (2002) nicht On-Board Diagnostics (OBD)
No new posts Getriebe im Polo 6n2 TDI Diesel Engine Technology
No new posts Polo 6N1 Gearbox DKE Transmission, Chassis, Body & Interior
No new posts Polo 9N3: Transmission leaking oil Transmission, Chassis, Body & Interior
