Spritzbeginn ändern: Ursachen & Lösungen
Kussi
Post23-06-2005, 18:59    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Two days ago, I posted a message (see June 22, 2005, 'Why does the TDI start so poorly?') where I described significant starting problems.
Now I've readjusted the fuel injection system and bled the ESP (a lot of air bubbles came out), and sure enough, the car starts perfectly again, even after being idle for a long time!
In the first exam for the SB course, I had an awful time, which I absolutely don't understand.
How can the SB (Steuergerät/control unit) adjust itself if there are no adjustments being made to the timing belt?
Does anyone have an idea? Because if this happens once, it will happen again, because the cause hasn't been addressed or identified! icon_smile.gif
Kisses.
Translated on 21-10-2026, 3:44.
lappen
Post23-06-2005, 19:26    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Why not continue in the old thread?
'Immediately, the K-screw comes to mind! Or maybe a loosening ESP (Electronic Stability Program). But the K-screw is probably more likely.'
Translated on 21-10-2026, 3:45.
Kussi
Post23-06-2005, 19:39    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Why not continue there?
Weil ich erstens denke, dass das Thema spezieller geworden ist und zweitens merke, dass die Aufmerksamkeit bei 'alten' Threads eben nicht mehr so groß und eben nicht speziell ist. Understandable?
Hmm, so it seems the crankshaft pulley bolt is loosening. Isn't the pulley secured against rotation with a pin, like with the ESP system? And then, why is it only shifting so little? If it were completely loose, nothing would probably work at all!
Kisses.
Translated on 21-10-2026, 3:46.
lappen
Post23-06-2005, 20:20    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Nein! Das Thema gehört in den alten Thread.... But never mind!
The countershaft gear is secured against twisting with a type of interference fit. However, if the screw loosens, the pressure of the gear on the countershaft stub is lost, and under the acting forces, this interference fit is 'worn' by the loose, moving gear. The result is that the gear rotates freely and uncontrollably on the countershaft stub. This leads to constantly shifting valve timing. I think it's only in extreme cases that nothing works at all. This would happen if the interference fit is completely destroyed, and the valve timing is then off by one tooth or more.
Use the search function and you'll find out!
Translated on 21-10-2026, 3:47.
Kussi
Post24-06-2005, 0:24    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Kann der Webmaster dann den von mir neu eröffneten Thread an den alten anhängen bzw. rüberkopieren? BeYou're right!
Ähm, wenn ich nach dieser Steuerzeitenverschiebung suchen will, unter welchem Begriff denn? Kannst Du mir da mal bitte einen Tip geben? 'Thank you!'
Kisses.
Translated on 21-10-2026, 3:48.
lappen
Post24-06-2005, 5:46    Subject: Spritzbeginn ändern: Ursachen & Lösungen Quote
Hmmmmmmm...
I'd try something like 'KW screw 1Z' or 'crankshaft screw 1Z.' Just be a little creative.
Translated on 21-10-2026, 3:49.
No new posts Do windows open on their own? General Tips
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spritzbeginn has changed after 20,000 km, is this normal? Diesel Engine Technology
No new posts Injection start cannot be adjusted on the 1Z Upload
No new posts Adjustable Injection Start: Not Configurable Diesel Engine Technology
No new posts Adjusting the power steering assist? Transmission, Chassis, Body & Interior
