Turbo Control Unit: Tapping into Boost Pressure (Image)
kossmann
2016 Audi Q3
Post19-03-2008, 21:23    Subject: Turbo Control Unit: Tapping into Boost Pressure (Image) Quote
Hello everyone,
I once accessed the engine control unit in an Audi 80 Avant (B4), 1.9 TDI (1Z), and I saw a pressure hose there... Can I attach a T-piece to that hose and connect a boost gauge? ... Or is that a completely different hose?
Here is the picture.
Thank you and best regards.
Translated on 08-09-2026, 9:24.
Post19-03-2008, 22:03    Subject: Turbo Control Unit: Tapping into Boost Pressure (Image) Quote
Hi Tino,
Yes, that works.
Translated on 08-09-2026, 9:25.
kossmann
2016 Audi Q3
Post26-03-2008, 16:31    Subject: Turbo Control Unit: Tapping into Boost Pressure (Image) Quote
"It worked out perfectly - thank you! I can't even remember why I ran those pressure hoses through the engine compartment back then (which I later had to repurpose for something else, so they're not there anymore)."
If I remember correctly, the boost pressure at full load used to be just under 1 bar (above atmospheric pressure). Yesterday, I didn't see it exceed 0.5 bar at the MAP sensor connection. Something doesn't seem right, does it?
Unfortunately, we can only check the laptop with software tomorrow.
Translated on 08-09-2026, 9:26.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {QUESTION} - Where is the best place to tap into the {TERM}? On-Board Diagnostics (OBD)
No new posts AHF performance measurement image and data on boost press... Upload
No new posts Image of a repaired engine control unit Diesel Engine Technology
No new posts Image of Agr Upload
