Sunroof Noises: Causes and Solutions
Post28-02-2008, 8:39    Subject: Sunroof Noises: Causes and Solutions Quote
After now exceeding 115,000 km, the 1J model is starting to show its age. I'm experiencing a creaking noise above me when driving over slight road imperfections, as if something is straining. I've ruled out the door seals, as the noise doesn't go away when applying pressure. The plastic guides on the sunroof also don't seem to be the cause, and the rails are lubricated. Subjectively, the noise seems to be coming from further back, from the area where the sunroof retracts when opening. I can't reproduce the noise by pressing on anything, nor can I stop it by pressing.
Does anyone recognize these sounds? They're quite new and really annoying. Any ideas before I start taking apart the ceiling?
Translated on 29-08-2026, 4:03.
Post28-02-2008, 10:45    Subject: Sunroof Noises: Causes and Solutions Quote
My G3 (my colleague has one, and I drove it again this weekend) is making a cracking sound with the SD card.
Everything was perfectly greased, but it still squeaks.
However, it can sometimes be resolved by opening and closing it again, and certainly by applying pressure to the glass in the cracking area.
It doesn't quite fit with the image you're trying to project.
I hadn't found the real cause until the sale, and the colleague is immune to noises coming from the car icon_wink.gif.
Translated on 29-08-2026, 4:05.
Post28-02-2008, 11:51    Subject: Sunroof Noises: Causes and Solutions Quote
It doesn't seem to be related to the glass lid, because the noise is the same regardless of its position. Since the noise is really annoying, it has to be fixed!
Translated on 29-08-2026, 4:06.
powermac
Post28-02-2008, 17:26    Subject: Sunroof Noises: Causes and Solutions Quote
Not an idea.
But here's a tip for locating the source of the noise.
Hab in einem früheren Wagen von mir auch so ein nerviges Geräusch gehabt. War der Meinung das es auch vom Himmel kommt. Hab auch gedrückt, gemacht und getan. Nix helped.
Ultimately, it wasn't the weather's fault.
The source of all the trouble was a rattling drawer located under the driver's seat.
Due to reflections, it appeared as if the light was coming from above.
The noises in a car often originate from somewhere completely different than you might think.
It's better to search for the noise with two people. One person drives, and the other person tries to locate the source.
Translated on 29-08-2026, 4:07.
Post29-02-2008, 8:23    Subject: Sunroof Noises: Causes and Solutions Quote
Hmm, yes, that sounds possible. I should also take a closer look at the passenger seat. It's kind of strange, even though it's getting warmer, it's starting to rattle...
Translated on 29-08-2026, 4:08.
Post04-03-2008, 8:34    Subject: Sunroof Noises: Causes and Solutions Quote
Well... it wasn't actually the sunroof, and the acoustics in the Golf also played a trick on me. Now I've located the main culprit. It's the rear right C-pillar trim... I'm curious to see what's underneath, because when I tap it lightly, it rattles quite a bit... icon_rolleyes.gif
Post04-03-2008, 10:13    Subject: Sunroof Noises: Causes and Solutions Quote
It's clipped to the body with some very large and robust metal clips.
Perhaps it's loose and now the squeaking monkey is making a metal-on-metal sound.
Translated on 29-08-2026, 4:09.
No new posts Audi A8 documentary: Creaking/grinding noises in the sunr... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Klappergeräusche von Schiebedach Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 05/99, sunroof stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sunroof Calibration: Basic Settings Transmission, Chassis, Body & Interior
No new posts Fine-tuning electrical devices. Sunroof in the A3 Transmission, Chassis, Body & Interior
No new posts Remote Sunroof & Window Closer: How To Diesel Engine Technology
No new posts Sunroof hose installation: Best practices. Transmission, Chassis, Body & Interior
