ASZ Engine Performance Issues: Troubleshooting & Logs
martsch
Post03-03-2008, 19:15    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
"I'm having the following problem... for the past 3-4 days, my vehicle hasn't been pulling at all; there's no power. About 30,000 km ago, I had a similar issue with the maximum speed, and thanks to your help, I replaced the mass airflow sensor, which resolved the problem. Now, I can hardly imagine that it would be defective again after such a short time. The symptom is a maximum speed of about 150 km/h, no acceleration above 2000 RPM; it's really struggling. Perhaps someone can help me. I did two diagnostic tests, once with codes 3-8-10 and 8-10. Unfortunately, I don't remember which one was the relevant code. If it's still important, the EGR valve is deactivated, which I did thanks to your help."
Thank you very much for your help.
MWB 3-8-10
/download.php?id=2922
MWB 8-10 (This likely refers to a specific product or standard and should be kept as is.)
/download.php?id=2921
Translated on 02-08-2026, 20:31.
Karma: +807 / -0   Thank you, like it!
Post03-03-2008, 19:55    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
"Yes, the LMM [likely mass airflow sensor] is probably faulty. The measured values are far too low (field 3 of MWB3 is not reaching 2). Is some kind of useless, cheap aftermarket air filter being used?"
Greetings, Rainer.
Translated on 02-08-2026, 20:33.
martsch
Post03-03-2008, 23:19    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
hello,
no, no sports air filter is being used, nor a chip or anything similar; everything is completely original. It's really a disgrace; the new one didn't last long at all icon_sad.gif.
Translated on 02-08-2026, 20:34.
Post04-03-2008, 7:27    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
Where did he get that from... eBay?
Is there a problem with the air intake before the air filter? Is the air filter noticeably "dirty"?
martsch
Post07-03-2008, 14:29    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
hello,
So, to my dismay, I just bought a new spark plug for €98.77 directly from VW, and absolutely nothing has changed. Of course, I immediately went for a drive, but there's no improvement; the engine feels exactly as weak as before, maybe slightly better, but that would probably be in the single-digit percentage range. What now? Should I measure any other parameters to try to figure out what's going on?
It really shocked me a bit; I thought that would solve the problem.
Thank you very much again for your replies.
best regards, martin
Translated on 02-08-2026, 20:36.
Post07-03-2008, 15:39    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
martsch wrote:
What now? Should I measure any other parameters to try and figure out what's going on?
Normally, a high LD value with poor LMM values, despite functioning electronics, usually indicates a vacuum leak between the MAF sensor and the compressor. Or (less commonly) it could be due to a severely clogged exhaust / catalytic converter.
I would start by checking the suction line for leaks.
Translated on 02-08-2026, 20:37.
joegolf
Post07-03-2008, 17:34    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
The boost pressure curve is strange. Also, it has overboost up to 1.7 bar.
 File size:  54.11 KB
 Viewed:  2408 times
Golf 7 GTI
Translated on 02-08-2026, 20:38.
martsch
Post07-03-2008, 19:37    Subject: Problem solved: Quick fix and solution Quote
hello,
I'm having this problem. Nevertheless, thank you very much for your answers. When I was driving along the intake manifold, I took a closer look in the engine compartment, and that's where I found the culprit. It's the EGR valve again, that damn plastic part that holds one of the levers has broken off again. It was hanging halfway, and it probably wasn't enough to trigger a limp-home mode like it did for me before, because this plastic part has already broken on my car once.
Despite everything, thank you for your efforts. I just wanted to mention the source of the problem here, because I don't like it when people help someone and then the person who started the thread doesn't explain what the issue was in the end.
Martin.
Translated on 02-08-2026, 20:39.
ammerlaender
Post07-03-2008, 19:59    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
Hello martsch!
I think it's great that you posted the cause; that's what makes a forum really useful.
Best regards, ammerlaender!
Translated on 02-08-2026, 20:40.
Post07-03-2008, 20:25    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
damn plastic part that holds this lever in place
Do you mean the lever from the shut-off valve? It's located in front of the EGR valve, which would make sense.
Translated on 02-08-2026, 20:41.
martsch
dieselschrauber likes this.
Post08-03-2008, 9:12    Subject: ASZ Engine Performance Issues: Troubleshooting & Logs Quote
hi,
Yes, exactly, I mean the lever from the parking brake.
No new posts Create VCDS log files and prepare them for the forum. Technical Articles
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T3 DZR AFN: Get Help & Advice Diesel Engine Technology
No new posts Who can help with a change of registration number? Diesel Engine Technology
No new posts LED Temperature Display - Get Help Now! Diesel Engine Technology
No new posts Used Car Buying: How VCDS Can Help You On-Board Diagnostics (OBD)
