REDIRECT,038-906-016-BGW.LBL,038-997-016-K ; BGW: (3B)
Okay, I found the line, but I can't find the file "038-906-016-BGW.LBL".
Laut rosstech Seite sollte sie aber im redirection packet dabei sein. Where can I find that?
Regarding the other questions, I would primarily like to have the ash mass calibration performed. The workshop didn't do that, and that's why I believe the soot calculation is incorrect.
The filter has been flushed, and the current reading is 68.2 MWB, which I estimate to be 156 grams. I would like to adjust this value.
The sulfur content was 0.8% to 1.8% (as indicated by the pulse width at MWB 68.1), after 8000 km, which doesn't seem right. (He didn't regenerate during that time.)
Does the question of "how" remain?
Is there a login code for that?
Similarly, I have a question about whether the logic code used for forced regeneration is the same as the one used in the forum.
EDIT: The login code for JAP is the same. I just performed a regeneration.
Thanks again, and sorry if I ask silly questions. I'm just trying to understand how the system works.
