Hi.
When I want to open my tailgate, I press on a rubber surface underneath which there's a touch-sensitive area with a microswitch.
Now it seems like there's dirt between the rubber and the touch surface, because there are little bumps that are moving around.
Do I need to remove the interior trim of the tailgate now, or is the component installed from the outside?
Translated on 30-09-2026, 19:40.
