| Webasto Heater Diagnosis: Retrofit Systems | ||||||||||||
| dieselschrauber |
To diagnose aftermarket installed Webasto auxiliary heaters, the diagnostic software from Webasto should be used:
http://lmgtfy.com/?q=Webasto+Thermo+Test+v.2.16+ru Our existing VCDS HEX-USB+CAN diagnostic hardware can be used for this purpose. Important: When retrofitting the heating system, the diagnostic cable must be connected to the auxiliary heater control unit! Here's what might be helpful: http://shop.dieselschrauber.de/break-out-box-obd2-multiplexer-p-315.php To use our VCDS diagnostic hardware with a USB connection: - Log in to the customer account and download the VCP driver (emulation of a virtual COM port). - Follow the instructions: https://community.dieselschrauber.org/en/viewtopic.php?t=17581
Dipl.-Ing. (FH) Rainer Kaufmann - Original VCDS mit KPower, KDataScope und Dieselschrauber Support Translated on 23-08-2026, 12:46. |
| Ratings - Webasto Heater Diagnosis: Retrofit Systems | |
Average rating: 4.00 - worst rating: 4 - best rating: 4 - number of ratings: 1 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.034s
