Boost pressure overshoot: 1905 mbar / 1911 rpm at ASZ
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
ASZ-Fahrer
Avatar-ASZ-Fahrer
2002 Audi A3
Post19-04-2008, 19:34    Subject: Boost pressure overshoot: 1905 mbar / 1911 rpm at ASZ Quote
see:
/viewtopic.php?t=18548&start=0&postdays=0&postorder=asc&highlight=&sid=c1e10fc71fd890128504261b0b8f8d42
Boost pressure, over and under. Undercut at
ASZ series, upgraded with new VTG (Variable Turbine Geometry) turbocharger, mass airflow sensor (MAF), and magnetic valve for the lambda sensor.
 Vollastbeschleunigung im 4. Gang
bei 1970 U/min 1,68 Bar IST zu 1,356 Bar SOLL (Umgebungsdruck 949mbar)
 File size:  82.21 KB
 Viewed:  724 times
 abwechselnd Volllast und Teillast
 File size:  93.09 KB
 Viewed:  840 times
LOG-01-004-003-008.xls
 MWB 4,3,8 von 1000-4100 U/min Volllast
 File name:  LOG-01-004-003-008.xls
 File size:  26 KB
 Downloaded:  352 times
LOG-01-004-xxx-xxx.xls
 MWB 4 im Leerlauf
MWB 4 im Leerlauf
 File name:  LOG-01-004-xxx-xxx.xls
 File size:  17.5 KB
 Downloaded:  376 times
MWB_3_8_10.xls
 MWB 3_8_10
MWB 3_8_10
 File name:  MWB_3_8_10.xls
 File size:  25 KB
 Downloaded:  334 times
LOG-01-011-SD.xls
 MWB Stellwerdiagnose
 File name:  LOG-01-011-SD.xls
 File size:  33.5 KB
 Downloaded:  306 times
MWB11.xls
 bei abwechselnd Teil-u. Volllast MWB 11 geloggt
 File name:  MWB11.xls
 File size:  28 KB
 Downloaded:  339 times
MWB11_Volllast.xls
 File name:  MWB11_Volllast.xls
 File size:  26 KB
 Downloaded:  431 times
Gruß Tobi
_________________
A3 8L1 PD ASZ EZ 06/02
Seriendatenstand
MSG 038906019 FT / 1,9l R4 EDC G000SG 1527
Laufleistung 120.000km
Translated on 06-07-2026, 19:46.
No new posts Boost pressure overshoot: 1905 mbar / 1911 rpm at maximum... On-Board Diagnostics (OBD)
No new posts Boost surge On-Board Diagnostics (OBD)
No new posts Boost Overrun: Causes & Solutions On-Board Diagnostics (OBD)
No new posts 2.5 TDI BDG: Boost Surge Explained On-Board Diagnostics (OBD)
