High Water Temperature: Causes & Solutions
tdi-seppl
Post17-05-2008, 9:37    Subject: High Water Temperature: Causes & Solutions Quote
"On my Audi 80 TDI with 90 horsepower and 290,000 km, the water temperature during normal driving is always around 100°C, often higher, and sometimes even reaches 110°C. The second stage of the radiator fan is almost always running. Previously, the operating temperature was always around 90°C, and it has gradually increased over the years. I assume the temperature gauge is accurate, because the thermostat switch activates the first stage of the radiator fan at approximately 95°C and the second stage at approximately 102°C. It's unlikely to be the thermostat of the water pump, because the radiator gets so hot that the thermostat switch in the radiator activates. The water pump was replaced about 2 years ago (without a thermostat). Could it be that the radiator is partially blocked (e.g., due to scale buildup)? Has anyone else experienced the same problem? I'm worried that this temperature will cause my "old car" to have a "heart attack"."
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 21-10-2026, 17:07.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post17-05-2008, 11:31    Subject: High Water Temperature: Causes & Solutions Quote
It sounds like you're saying: the engine's cooling system isn't working properly; the cooling capacity of the radiator is insufficient. Check the temperature. Add coolant or replace it.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 21-10-2026, 17:08.
Post17-05-2008, 16:06    Subject: High Water Temperature: Causes & Solutions Quote
Often, even in vehicles with air conditioning, with this kind of mileage, the air conditioning condenser (radiator) and the water cooler become so heavily soiled that heat can hardly be dissipated. This is easily checked by loosening the condenser bracket and tilting it slightly forward to see if it's heavily soiled. This is especially common in vehicles that are frequently driven on high grass. If not, I agree with my predecessor.
Translated on 21-10-2026, 17:09.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-05-2008, 18:00    Subject: High Water Temperature: Causes & Solutions Quote
How about the heating capacity of the heating heat exchanger?
Should the temperature (approximate value) be measured at a minimum of 70°C?
At least at the medium blower setting.
the outside temperature.
fast engine speed,
Cooling water temperature: minimum 85°C.
If it's also cold, meaning 40-50 degrees Celsius, then rinse it.
If it's overheating, the engine radiator might be clogged internally or externally, as mentioned above.
Translated on 21-10-2026, 17:10.
tdi-seppl
Post18-05-2008, 13:06    Subject: High Water Temperature: Causes & Solutions Quote
First of all, thank you very much for the answers.
I've decided to install a new cooler.
I don't think much of the radiator cleaner.
"The cooler costs €125 including shipping, and it's supposedly the same quality as the original."
I'll let you know if it really was the cooler.
Translated on 21-10-2026, 17:11.
Kolbenring
Karma: +6 / -1   Thank you, like it!
Post22-05-2008, 9:39    Subject: High Water Temperature: Causes & Solutions Quote
How was the problem resolved? Did the new cooler fix the issue?
Translated on 21-10-2026, 17:12.
tdi-seppl
Post23-05-2008, 16:42    Subject: High Water Temperature: Causes & Solutions Quote
I installed a new water cooler today.
Now he has a normal temperature again.
The old one contained a brownish broth.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post23-05-2008, 16:55    Subject: High Water Temperature: Causes & Solutions Quote
I hope you flushed it with some cleaner. The rust-colored liquid can also get into the radiator!
Translated on 21-10-2026, 17:13.
Post23-05-2008, 16:59    Subject: High Water Temperature: Causes & Solutions Quote
...and rinse it the other way, so that the sludge also comes out.
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Code P2463: High Soot Mass Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts LMM values too high! Diesel Engine Technology
No new posts High Boost Pressure: Causes & Solutions Upload
No new posts High Boost Pressure (AFN) Explained Diesel Engine Technology
No new posts LMM Value Too High? Troubleshooting Guide. On-Board Diagnostics (OBD)
