Inkjet Printer Cartridge Exchange Program
roorback
Karma: +1 / -2   Thank you, like it!
Post28-05-2008, 15:01    Subject: Inkjet Printer Cartridge Exchange Program Quote
hey
The injectors in my 5-cylinder TDI AEL engine in my Volvo need to be replaced.
Which injectors are originally used for the engine, and which injectors could I use for a slight performance increase?
"Thank you."
best regards, uwe
Translated on 15-10-2026, 12:44.
Karma: +807 / -0   Thank you, like it!
Post28-05-2008, 19:45    Subject: Inkjet Printer Cartridge Exchange Program Quote
http://shop.dieselschrauber.de/product_info.php/products_id/281
and
http://shop.dieselschrauber.de/product_info.php/products_id/77
Translated on 15-10-2026, 12:45.
roorback
Post29-05-2008, 6:52    Subject: Inkjet Printer Cartridge Exchange Program Quote
Sure, here's the translation:
"Thank you!"
roorback
Post29-05-2008, 11:55    Subject: Inkjet Printer Cartridge Exchange Program Quote
"Still, I have one more question: if the 216 models are 'tuned nozzles,' what are the others, or the original ones?"
And what about the tuning nozzles? Should they be combined with chip tuning, or can/should they provide a certain increase in performance on their own, without chip tuning?
"Thank you."
best regards, uwe
Translated on 15-10-2026, 12:46.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post30-05-2008, 12:47    Subject: Inkjet Printer Cartridge Exchange Program Quote
If Rainer recommends the 216s, then the originals are probably the 205s.
Replacing the injectors will give you a healthy and subtle performance boost, while also ensuring that the injectors have been refurbished.
Using it simultaneously with a conventional chip is not recommended, as too much fuel would be injected, which could damage the engine or cause excessive smoke.
Simultaneous use with specially designed software is possible.
I don't know if Rainer has something like that in his program, or if he could program it for you.
But if you inquire, please do so not in "time theft" mode, but only if there is a genuine interest icon_wink.gif.
Translated on 15-10-2026, 12:47.
roorback
Post31-05-2008, 17:09    Subject: Inkjet Printer Cartridge Exchange Program Quote
hey
Thank you for the reply. Yes, I have a TDI with a chip, and it performs very well. In my opinion, it's fine as it is, and I don't want any more power.
and on the second one, I need to replace the nozzles, but that won't increase its performance.
That's exactly the effect I was hoping for with the new nozzles and a little more power, so I'll give it a try.
"Thank you."
best regards, uwe
Translated on 15-10-2026, 12:48.
