AU ARL Haze Values: Measurement & Analysis
g1om
Post12-06-2008, 21:35    Subject: AU ARL Haze Values: Measurement & Analysis Quote
Today I had the mandatory vehicle inspection (AU) done on my Seat Leon with a 70,000 km mileage. It was overdue by a bit.
After some initial difficulties related to the OBD system, it eventually worked.
However, I was somewhat surprised by how high the turbidity level was.
I have a value between 0.8 m/1 and 0.9 m/1.
He definitely passed the exam easily; the passing score is far below his result.
However, I would like to know from you what the turbidity values were for your AU (Automated Urine Analyzer) when using ARL (presumably a specific reagent or solution).
It would be great if you could check your vacation request form and then post about it.
Sure, no problem. Here's the translation:
'Thanks in advance.'
Translated on 05-08-2026, 23:12.
RTDI-Tom
Post13-06-2008, 5:45    Subject: AU ARL Haze Values: Measurement & Analysis Quote
With my highly optimized ARL (alternative loading system, different PDEs, etc.), the turbidity values on Tuesday were 0.00 / 0.00 / 0.01.
Translated on 05-08-2026, 23:13.
Post13-06-2008, 8:10    Subject: AU ARL Haze Values: Measurement & Analysis Quote
RTDI-Tom wrote:
With my extremely high-performance ARL (different charger, different PDEs, etc.), the turbidity values on Tuesday were 0.00 / 0.00 / 0.01
Meßfehler, d.h. Quark measured.
We're not on some amateur forum here. There are enough people reading this who make trading decisions every day. You shouldn't try to mislead either them or inexperienced newcomers.
Translated on 05-08-2026, 23:14.
RTDI-Tom
Post13-06-2008, 9:05    Subject: AU ARL Haze Values: Measurement & Analysis Quote
'I don't want to make anyone feel like I'm trying to deceive them. I don't take sick leave every day; it's only every two years, and the last time was just on Tuesday. And those are the values that are recorded in the report. I have the original report, but I wasn't present during the examination itself. If incorrect measurements were taken, I apologize, and I'm happy to retract the values I posted. We'll see what comes out next time.'
Translated on 05-08-2026, 23:15.
Post13-06-2008, 9:24    Subject: AU ARL Haze Values: Measurement & Analysis Quote
Yes, you can safely disregard that statement because it's completely unrealistic.
Translated on 05-08-2026, 23:16.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-06-2008, 12:05    Subject: AU ARL Haze Values: Measurement & Analysis Quote
The initial series values are already significantly higher!
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post13-06-2008, 13:31    Subject: AU ARL Haze Values: Measurement & Analysis Quote
I was somewhat surprised, however, that the turbidity was so high.
Depending on the driving style, this is quite normal.
g1om
Post13-06-2008, 17:12    Subject: AU ARL Haze Values: Measurement & Analysis Quote
Does the driving profile actually not play a role in the vehicle inspection (AU)?
With both measurement methods, whether it's for diesel engines or diesel engines with OBD (On-Board Diagnostics), the time taken during free acceleration and any resulting emissions are measured.
The only difference is that the readiness code appears on the diagnostic report when using OBD.
Otherwise, it's essentially a certificate that doesn't include the OBD system.
You can only achieve values of 0.00 with a DPF, and that's only in a closed system. However, I haven't encountered anything like that for the ARL icon_wink.gif.
Translated on 05-08-2026, 23:18.
Post13-06-2008, 20:42    Subject: AU ARL Haze Values: Measurement & Analysis Quote
Isn't the driving profile not actually used in the general inspection (AU)?
Yes, because the exhaust system is also more or less filled with soot deposits, which are then expelled when you accelerate fully.
The main problem is with "persistent leakers," because then you end up with a significant amount of accumulated sludge over many, many kilometers. icon_smile.gif
Regardless, the intake manifold is more or less coated with deposits depending on whether or not an EGR system is being used.
Translated on 05-08-2026, 23:19.
bloesch
Post13-06-2008, 21:17    Subject: AU ARL Haze Values: Measurement & Analysis Quote
A thought-provoking idea:
"An AU (presumably referring to a specific tool or device) can quickly earn money for any mechanic (or improve their efficiency)."
Failed inspections are not in the best interest of the mechanic, the customer, or the workshop management.
So, do these things also get AU?
In my experience, a car has never failed the emissions test (unless there were defects or leaks). Somehow, it always works out.
Recently, a particular Octavia 2 diesel stubbornly refused to start during its inspection.
He then passed the test with similar levels of interference as the car belonging to RTDI-Tom.
Translated on 05-08-2026, 23:21.
g1om
Post15-06-2008, 11:28    Subject: AU ARL Haze Values: Measurement & Analysis Quote
I didn't intend to start a discussion about the correct way to perform an audit, but rather just wanted to ask for some comparison values.
If any of my mechanics try to cheat during the vehicle inspection ('AU'), they will receive exactly two things from me: 1) A written warning, and 2) Revocation of their authorization to perform 'AU' inspections.
It is absolutely not in the workshop management's interest for a vehicle to pass the emissions test!
Quite the opposite: Failing the initial inspection means follow-up work, including troubleshooting, subsequent repairs, and another inspection, which all generate revenue.
If someone doesn't pass the exam, they don't pass! If they ever catch you cheating, you'll know what I mean!
Translated on 05-08-2026, 23:23.
cetano
Avatar-cetano
Post24-06-2008, 14:46    Subject: AU ARL Haze Values: Measurement & Analysis Quote
....0.9m/1... what unit of measurement is that?
I only know the K-value in a diesel exhaust test. The K-value is a reference number related to the measured number of particles per unit volume (ppm - parts per million, which are cumbersome units). The relationship is close to an exponential function.
Here are some workshops where cars consistently pass the emissions test...
I know of some workshops like that, but they are few and far between. However, they generally have a bad reputation because many other aspects are also questionable.
It is also not in the best interest of a (reasonable) customer if an abnormality or defect in their engine or engine management system is not detected or intentionally overlooked, especially since consequential damage may occur.
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 05-08-2026, 23:25.
Back to top Profile PM Email
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post24-06-2008, 20:08    Subject: AU ARL Turbidity Values: Explanation & Guide Quote
g1om wrote:
Today, I had the overdue emissions test (AU) done on my Seat Leon with a 70,000 km mileage.
Thanks in advance
The values might be close. Maybe practice driving properly before the inspection, going above...
4000 RPM to initially remove ash from the exhaust system icon_smile.gif.
Besides the turbidity values of 0.0/m or 0.01/m, only vehicles that originally came with a particulate filter from the factory have those values.
B.Eng (FH) u. KFZ Meister
Translated on 05-08-2026, 23:27.
Post25-06-2008, 6:20    Subject: AU ARL Haze Values: Measurement & Analysis Quote
With a vehicle that doesn't have a particulate filter, the readings shouldn't be consistent with a proper measurement, no matter how much the vehicle has been driven previously.
Translated on 05-08-2026, 23:29.
charlyfirpo
2013 Volkswagen Golf
Post27-06-2008, 20:57    Subject: AU ARL Haze Values: Measurement & Analysis Quote
Hello.
I just checked. The values are 0.7, 0.9, and 0.7 for the AU (likely referring to a specific medical test or measurement) in February 2008. Considering the threshold of 2.0, I see these as normal.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 05-08-2026, 23:30.
No new posts ASU - Turbidity Values Diesel Engine Technology
