Swapping suspension springs on a VW Eos
bakkano
Post25-06-2008, 14:38    Subject: Swapping suspension springs on a VW Eos Quote
My girlfriend bought an Eos.
2.0 TDI.
It has the standard suspension.
Part numbers for springs 1K0 411 105. PR-2UA+L19
I would like it to be a bit more staggered.
I've already looked up the part numbers for other springs from the Eos.
There are only 2 letters at the end that are different.
Go from.
1K0...DA PR2UC+L55
1K0...DB PR2UC+L58
1K0...DC PR2UC+L59
1K0...DD PR2UC+L62
1K0...DE PR2UC+L63
1K0...DF PR2UC+L68
Which one can I take?
Post25-06-2008, 18:01    Subject: Swapping suspension springs on a VW Eos Quote
A subtle lowering kit from a reputable manufacturer is the best option; for example, FK is not a brand I would recommend.
It might still be cheaper than the Orschinols garbage, which only works properly when used with the matching dampers.
Best regards, Rüdi.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GTI springs Transmission, Chassis, Body & Interior
No new posts Feathers of steel? Transmission, Chassis, Body & Interior
No new posts Fuel Injector Shim Springs for ALH Engine Diesel Engine Technology
No new posts VW 1J 4Motion: Rear Spring Replacement Transmission, Chassis, Body & Interior
