Diesel Pump Not Working: Troubleshooting Guide
poppel
Karma: +1 / -2   Thank you, like it!
Post19-06-2008, 0:18    Subject: Diesel Pump Not Working: Troubleshooting Guide Quote
Hello, I'm having the following problem:
T4 AAB 2.4 Diesel, fuel injection pump failure.
Ordered a used one from a dealer, it arrived today, I installed it, set the start-up time, pre-filled the pump, started it, the motor runs briefly, then stops.
Everything checked: valve timing, fuel injection start, etc. Diesel filter, hoses, nothing.
What's noticeable is that the pump isn't drawing any diesel.
When I loosen the cap nuts on the injectors during startup, only a small amount of diesel comes out. The fuel line from the filter to the pump is empty.
Could it be that the pump is broken, or have I missed something? The pump should definitely be drawing fuel, right?
Poplar is stupid, at least today I'm only selling diesel.
Translated on 18-09-2026, 13:51.
DieselBär30x
Avatar-DieselBär30x
Post20-06-2008, 23:10    Subject: Diesel Pump Not Working? Troubleshooting Guide Quote
poppel wrote:
...The line from the filter to the pump is empty. ...
Hello!
What does that mean EXACTLY?!
If it's "filled" with air, it's probably obvious icon_wink.gif.
Best regards from Munich!
Translated on 18-09-2026, 13:52.
poppel
Post20-06-2008, 23:13    Subject: Pump: Types, Uses & How They Work Quote
The pump is naturally filled with diesel.
And the pump is broken.
Translated on 18-09-2026, 13:53.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post20-06-2008, 23:50    Subject: Diesel Pump Not Working: Troubleshooting Guide Quote
Fill the filter and inlet hose completely. Fill the reservoir with diesel. Hang the fuel lines. Open the nozzle lines. If diesel starts flowing, close one or two lines and continue starting.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post21-06-2008, 14:18    Subject: Diesel Pump Not Working: Troubleshooting Guide Quote
teileklaus wrote:
Fill the filter and inlet hose completely. Fill the reservoir with diesel. Hang the diesel tank high. Open the nozzle lines. If diesel starts to flow, tighten one or two lines and continue starting.
Or something like a small rubber bellows pump, like the ones that were originally installed on PSA engines, could be placed in the return line and operated until all the air is purged from the system.
Best regards, Rüdi.
Translated on 18-09-2026, 13:54.
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 5, Fahrzeug zieht nach links oder rechts Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel zieht die Wurst nicht mehr vom Teller Diesel Engine Technology
No new posts VAG-COM adapter not getting power! On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. A4 TDI 2.0 PD injectors are not injecting fuel after ZK r... Diesel Engine Technology
No new posts VP44 no longer delivers high pressure Diesel Engine Technology
