2x2 Pin Configuration: Older Models Explained
haehnlein
Post03-01-2003, 23:12    Subject: 2x2 Pin Configuration: Older Models Explained Quote
How are the old 2x2-pole connectors used for the error memory?
Audi 80 TDI, manufactured in 1994.
Thank you in advance icon_exclaim.gif icon_exclaim.gif.
Best regards, Christian.
Translated on 24-09-2026, 6:44.
Andy
Post03-01-2003, 23:36    Subject: 2x2 Pin Configuration: Older Models Explained Quote
Here's a picture of it.
and the occupancy:
white connector:
top: K-line
bottom: L-line
black connector:
top: 12V+
bottom: ground
See you then.
Andy.
 File size:  57.37 KB
 Viewed:  105 times
Translated on 24-09-2026, 6:45.
haehnlein
Post04-01-2003, 13:29    Subject: 2x2 Pin Configuration: Older Models Explained Quote
@Rainer:
It would be helpful to include the image in the technical article about the diagnostic adapter icon_exclaim.gif icon_question.gif.
Translated on 24-09-2026, 6:46.
Frank32
Post04-01-2003, 19:00    Subject: 2x2 Diagnostic Socket Quote
Hello.
I also have a question about the 2x2 diagnostic connector.
I have a Passat, model year 1991, with a 2E engine and 115 horsepower.
He also has these two connectors underneath the control unit. Can I also query it using the diagnostic circuit shown on this page?
Do I absolutely have to use a VAG-COM device?
Thank you in advance!
Frank.
Translated on 24-09-2026, 6:47.
Post04-01-2003, 22:10    Subject: 2x2 Pin Configuration: Older Models Explained Quote
Hello Christian,
I'm including the image in the article.
No new posts Retrofit DPF for older R5 TDI (AEL)? Diesel Engine Technology
No new posts VCDS for Porsche Models On-Board Diagnostics (OBD)
No new posts Piston Retraction Tool: Do You Need It for VAG? Transmission, Chassis, Body & Interior
No new posts 12V Socket Wiring: Pinout and Connections Diesel Engine Technology
