Common Rail Injectors: LT 35 Refurbishment?
luiggi
Post01-07-2008, 18:13    Subject: Common Rail Injectors: LT 35 Refurbishment? Quote
I have a quick question: Can the Bosch injectors (0445 110 081) from an LT 35 with an AUH engine not be refurbished or repaired by someone, meaning, can they be re-sealed, etc.? My vehicle sometimes stalls, and this is attributed to the injectors. This problem is also known in VW vehicles, specifically between 2002 and 2003. I was told that these injectors can only be replaced with new ones. The cost of one injector is €469! So, in my case, that would be 4 injectors. Thanks.
Translated on 03-10-2026, 6:16.
efistho
Post02-07-2008, 7:55    Subject: Common Rail Injectors: LT 35 Refurbishment? Quote
Wende Dich mal an die Fa. Herrmanns.
http://www.goherrmanns.de/Mercedes-Benz-Motoren/Mercedes-Injektoren.aspx
Very competent shop. I often have them work on my CDI injectors.
Since it's Bosch, that shouldn't be a problem.
Best regards, efistho.
Translated on 03-10-2026, 6:17.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
No new posts Common-Rail TDI with knocking noises between at 1400 RPM Diesel Engine Technology
