New tax device adapted to existing WFS
Go to page: 1, 2  Next
marcel.d
1997 Volkswagen Golf
Post15-09-2008, 13:02    Subject: New tax device adapted to existing WFS Quote
Since my current engine control unit is defective, I have purchased a new, used one. However, since I need a WFS (Vehicle-to-System interface) in the vehicle, the existing WFS and the new ECU must be adapted to each other. How can I do that best?
VAGcom 3.03, OBD-cable and laptop are available. This car is a 1997 Volkswagen Golf 3 Variant with a 110 hp TDI AFN engine.
If an instruction manual for patching is not allowed to be publicly posted, please send me a private message.
Post15-09-2008, 13:18    Subject: New tax device adapted to existing WFS Quote
Why don't you use VAG-COM 3.112?
marcel.d
Post15-09-2008, 13:25    Subject: New tax device adapted to existing WFS Quote
because I don't have it. Where can I get it? And how do I adapt the STG and WFS?
Post15-09-2008, 14:22    Subject: New tax device adapted to existing WFS Quote
Please download version 311.2 from Ross-Tech first, then we can proceed.
Hello, Rainer
marcel.d
Post15-09-2008, 14:31    Subject: New tax device adapted to existing WFS Quote
Okay, I just downloaded it. And now?
Post15-09-2008, 14:45    Subject: New tax device adapted to existing WFS Quote
Now save to the combination instrument (address 17) and adjustment channel 0.
Hello, Rainer
Post15-09-2008, 14:47    Subject: New tax device adapted to existing WFS Quote
Oops, it's a Golf 3, So then address 25 (WFS Steuergerät).
Before saving in the adjustment channel, enter the login code on the plastic key fob as a login (include a leading 0 to make it 5 digits).
marcel.d
Post15-09-2008, 15:14    Subject: New tax device adapted to existing WFS Quote
On my keys (3 original and one folding key) there is no login code! Can I get one retroactively from VW? The login code is for the WFS or the STG?
Post15-09-2008, 18:21    Subject: New tax device adapted to existing WFS Quote
The login code is for the WFS. It's a small plastic card with 4 digits.
Hello, Rainer
marcel.d
Post18-09-2008, 15:04    Subject: New tax device adapted to existing WFS Quote
I have now read that the login code is not actually needed, but that you should first select the VAGCom 1 engine control unit, then select the channel to adjust or adapt, then read channel 00 and then save the value 00. The same applies to the STG of the WFS. Is this correct?
Post18-09-2008, 15:29    Subject: New tax device adapted to existing WFS Quote
Here's how WFS Version 2 works.
Best regards, Rainer
marcel.d
Post18-09-2008, 19:59    Subject: New tax device adapted to existing WFS Quote
Does the Golf 3 TDI, manufactured in 11/97, not already have WFS version 2?
What about my current keys? Do they also need to be reprogrammed?
Post19-09-2008, 7:07    Subject: New tax device adapted to existing WFS Quote
Hi, good question, I think more WFS1.
The keys are independent of the engine control unit, so no changes are needed.
marcel.d
Post20-09-2008, 12:08    Subject: New tax device adapted to existing WFS Quote
The new STG arrived yesterday. The VW part number is 028906021 GL, while my old one had the letters GH. The Bosch part number also has a different last digit. New: 6, Old: 2
An expression from 2005, when the STG was purchased, is also present, and it states that it was for the Passat and A4. Therefore, it was for both VW and Audi. I'm curious to see if this works on Monday...
marcel.d
Post23-09-2008, 6:25    Subject: New tax device adapted to existing WFS Quote
Okay, I finished adjusting it yesterday. It took about 5 minutes. Finally, I don't have those annoying error codes anymore, like "suction pressure regulation difference" or "control unit defective," even after I've given it some gas.
Post23-09-2008, 15:58    Subject: New tax device adapted to existing WFS Quote
Yes, have you used the login (PIN) yet? So, WFS1 or 2 for the car?
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vacuum Regulator Issues: New Control Unit, Same Problem On-Board Diagnostics (OBD)
No new posts Injector Pump Control Unit Tuning/Adjustment On-Board Diagnostics (OBD)
No new posts Skoda Octavia RS: Adjust Steering Control Unit On-Board Diagnostics (OBD)
No new posts Timing Belt Replacement: New & Improved!;-) Diesel Engine Technology
