Passat 2.0 TDI Shakes: Causes & Solutions
samoht
Karma: +1 / -1   Thank you, like it!
Post09-07-2008, 9:17    Subject: Passat 2.0 TDI Shakes: Causes & Solutions Quote
My friend's 3C Passat 2.0 TDI with 103 kW (140 hp) occasionally jerks during acceleration in 1st and 2nd gear at 2000-2200 RPM. The jerking is sporadic and cannot be reproduced, and it occurs regardless of whether the engine is warm or cold.
The workshop can't find any faults.
I'll be getting the new VCDS soon.
How should I approach troubleshooting?
Or is the PD cable, or PD components, a promising candidate?
Translated on 04-10-2026, 23:08.
vagtuning
Post09-07-2008, 15:05    Subject: Passat 2.0 TDI Shakes: Causes & Solutions Quote
The wiring harness to the PDEs is the leading suspect.
A log drive using VCDS and diagnostic trouble codes (DTCs) 18 and 23 should help identify the cause of the issue.
to be sufficient.
Otherwise, I will gradually post troubleshooting guides in this forum.
First, it would be interesting to get a 3D scan of the car.
Translated on 04-10-2026, 23:10.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Passat B6 140hp TDI Diesel Engine Technology
No new posts Limitation Maximum Speed Passat 3C 140PS TDI DPF Diesel Engine Technology
No new posts Bitte um Hilfe: Passat AJM ruckelt On-Board Diagnostics (OBD)
No new posts Passat B5 TDI: Engine Misfire at Low Load Diesel Engine Technology
