Limitation Maximum Speed Passat 3C 140PS TDI DPF
Go to page: 1, 2  Next
hharry
Karma: +2 / -1   Thank you, like it!
Post27-03-2008, 10:18    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
I've recently started driving a Passat 3C Variant TDI with 140 hp and DPF as a company car. Now I've noticed that the maximum speed is exactly 218 km/h on the speedometer, but when measured with GPS, it's actually 207 km/h. This means that the engine cuts back, which I can clearly feel when going downhill on the highway. Does anyone of you know about this problem?
It's quite frustrating because you think it could still go much further...
Greetings to everyone
Harald
Post27-03-2008, 10:39    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
Hm
The vehicle is registered under the license plate 206. That means everything is fine.
What software version does your motor control unit (ECU) have?
A 11/2006 variant with the BMP engine in my environment is actually running at 220-230 km/h according to the speedometer.
Jochen_145
Post27-03-2008, 11:29    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
The 'reconciliation software' only appeared with the latest updates...
But if a software update has been installed, it is highly likely that the V_max limit is now active.
Jochen
Post27-03-2008, 12:01    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
If the limit based on the intended capabilities of the EDC16 is implemented, it is also possible to read the limit.
There's 300 km/h listed for it... and he can manage icon_smile.gif 250 of them.
Jochen_145
Post27-03-2008, 12:36    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
If the limit is set using the predefined EDC16 capabilities, the limit can also be read out.
Yes, it is present in the dataset and can be modified if the parameter is found.
With my car, it reaches 300 km/h... icon_smile.gif and he can achieve 250 km/h.
Do you also have a Siemens-VDO ECU?
Best regards, Jochen
P.S. Does anyone know if the Audi A3 with 170 hp also has the Siemens ECU, or is Bosch used here? I'm betting on Siemens, as I expect the PPE... but I'm not sure exactly icon_cry.gif
Post27-03-2008, 12:54    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
As far as I know, all the 170 PPDs have the Siemens-VDO ECU, because the PPEs also have them.
Component: J623 - Engine Electronics (#01) - BMN/BMR/BUY/BUZ 2.0l TDI-PPD
Regarding the limitation, my Siemens box also has the same measurement blocks as Bosch ECUs, or?
pschaefer
Post27-03-2008, 20:57    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
Jochen_145 wrote:
P.S. Does the Audi A3 with 170 hp also have the Siemens ECU, or is Bosch used here? I'm betting on Siemens, as I expect the PPE... but I don't know for sure icon_cry.gif
It's definitely Siemens/Conti-VDO:
Address 01: Motor
Part Number SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 1185
Encoding: 0000078
Unfortunately, he/she is not 250 years old. With very stiff 230/Tacho, it's time to stop (which probably corresponds to the registered 223).
Greetings
Pete
Post27-03-2008, 22:18    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
I admit that the 250 is only according to {SOURCE}. Speedometer and, with the help of a Berg inside icon_wink.gif
hharry
Post28-03-2008, 10:31    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
dieselmartin wrote:
Hmm
I'll try to read it out over the weekend. I recently bought an old interface from Uwe Ross from the early days in the USA, and I haven't tested it on my new Passat yet. It worked perfectly on my Golf 4.
mullemaus
Post30-03-2008, 18:47    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
The Passat 3C requires a CAN-Bus interface. You won't get far with an ancient one icon_wink.gif
Post30-03-2008, 22:21    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
As far as I know, the engine is still using the K-Line.
The transmission, too.
But then, communication becomes impossible.
smith2
Post17-06-2008, 0:08    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
Hello, I (professionally) drive a Golf V with a 2.0 TDI engine and 140 horsepower, and it looks the same. Where can I view and potentially edit this boundary?
Post17-06-2008, 13:27    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
In the dataset. There's nothing you can do with a VAG-COM/VCDS to check or edit this, because it's handled differently than the adjustable top speed limit.
Best regards, Rainer
smith2
Post25-06-2008, 19:48    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
What does this mean? What tools can be used to edit it? Who could do something like that?
Why was this restriction introduced?
Stefan-TDI
1997 Volkswagen Golf
Post29-06-2008, 21:55    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
To ensure longevity, the engine has been reduced in power.
Post30-06-2008, 8:26    Subject: Limitation Maximum Speed Passat 3C 140PS TDI DPF Quote
Shelf life?
Well, of course, there are reasons that make sense. For example, if the registered maximum speed has been reached, then it should be sufficient. Only a nice man like Rainer can help you now, who can assign other information to your MSG's internal components...
Perhaps manufacturers are trying to demonstrate improved performance more effectively. I don't know how many idiots are constantly speeding on the highway in their cheapest, performance-enhanced vehicles and what gets left behind on the road...
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Passat B6 140hp TDI Diesel Engine Technology
No new posts Passat 2.0 TDI 103kw(140PS) ruckelt. On-Board Diagnostics (OBD)
No new posts Boost Too High: No Limit on Audi AFN Engine? Diesel Engine Technology
No new posts Begrenzung über Drehmoment, was ist das innere Moment Diesel Engine Technology
