Relationship between boost pressure and valve timing
tsfreak
Post22-08-2008, 16:48    Subject: Relationship between boost pressure and valve timing Quote
Hello!
I have now resolved the issues I was having with boost pressure overruns, as mentioned in previous posts. Two vacuum hoses were leaking.
Now, let's get to the main topic.
With different settings of the valve timing, I observed that the LD (likely referring to a specific measurement or value) is approximately 0.1 lower when comparing, for example, KW 0° to KW + approximately 3°. Is this a more positive effect, or a less significant one? (The driving behavior is quite good.)
My thought is that if the initial air-fuel ratio is slightly low, more air will be drawn in, resulting in a better ratio of diesel to air.
Am I correct here, or am I making a mistake?
Please explain it to me.
Thank you for your expert information.
Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Relationship between LMM and boost pressure? Diesel Engine Technology
No new posts LMM Values & Boost Pressure: Unclear Relationship? Diesel Engine Technology
No new posts RPM, Boost & Air Mass: The Connection Diesel Engine Technology
No new posts 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in gen... Diesel Engine Technology
