WFS Issues After AWS Account Migration
bluestartdi
Post13-04-2008, 15:58    Subject: WFS Issues After AWS Account Migration Quote
Here's the translation:
"I have a problem: I converted my van with a 1.9L TDI engine (MBK AFN)."
Now that everything is ready and I want to start it, it won't start. I then used VAG-COM to read the engine control unit and immobilizer, and lo and behold, it found two errors.
Error 1.
VAG-COM version: DRV 311.3-S.
Control unit part number: 1H0 953 257 B.
Component and/or version: IMMO VWZ3Z0V4372023 V00.
Encoding: 09600
Workshop code: WSC 00000
"One error found:"
01176 - Key
65-10 - unauthorized - occasional.
and error 2.
Control unit part number: 028 906 021 GH.
Component and/or version: 1.9L R4 EDC G60SG MOZZ
Encoding: 00002
Workshop code: WSC 01269.
"One error found:"
17978 - Engine control unit locked.
P1570 - 35-00 - -
Can someone here possibly help me or tell me how to troubleshoot this? I've already tried everything with VAG-COM.
Okay, so all the parts come from a single vehicle.
Thank you very much for your help.
Michael
EDIT Mode: Title with a statement
Translated on 17-08-2026, 9:09.
mullemaus
Post13-04-2008, 16:17    Subject: WFS Issues After AWS Account Migration Quote
Here's a concise translation:
In short: The immobilizer is active. With the version of VCDS you are using, pairing new keys will be problematic. Try clearing the learned values in the engine control unit and deleting all memory data. Then try again. However, systems from the WFS Generation I always require login. If you don't have that, it will be difficult. icon_wink.gif
Translated on 17-08-2026, 9:13.
bluestartdi
Post13-04-2008, 16:24    Subject: WFS Issues After AWS Account Migration Quote
"That's probably my problem. How do I clear everything from the control unit? Because I don't have a function to read and erase all memory; I can only read the control unit, then go to error codes, and it immediately shows that my engine control unit is locked. And even when I try to clear the errors, they reappear. Maybe I need a different VAG version or something. I currently have versions 311 and 303 on my computer."
Hi Micha,
mullemaus wrote:
In short: The immobilizer is active. With the version of VCDS you are using, pairing new keys will be problematic. Try clearing the learned values in the engine control unit and deleting all memory contents. Then try again. However, systems from the WFS Generation I always require a login. If you don't have that, it will be difficult. icon_wink.gif
Translated on 17-08-2026, 9:14.
mullemaus
Post13-04-2008, 16:41    Subject: WFS Issues After AWS Account Migration Quote
That will probably be my problem. How do I erase everything from the control unit? Because I don't have a function to read and clear all memory; I can only read the control unit, then go to error codes, and it immediately shows that my engine control unit is locked. And even if I try to clear the errors, they reappear. Do I maybe need a different VAG version or something? I currently have versions 311 and 303 on my computer.
Hi Micha,
In short: The immobilizer is active. With the version of VCDS you are using, pairing new keys will be problematic. Try clearing the learned values in the engine control unit and deleting all memory data. Then try again. However, systems from the WFS Generation I always require a login. If you don't have that, it will be difficult.icon_wink.gif
I haven't heard anything good about the 311. A full version is necessary for adaptations. For immobilizer type I, you also need the login code. Without these two things, it will be difficult.
PS: Did you know that the engine control unit is no longer a standard part? icon_cool.gif icon_wink.gif
Translated on 17-08-2026, 9:16.
bluestartdi
Post13-04-2008, 16:45    Subject: WFS Issues After AWS Account Migration Quote
I already have the full version here; I've licensed and have free access to both versions. I don't have the login code, which is correct. Why shouldn't my control unit still be in its original state?
mullemaus wrote:
Hi Micha,
PS: Did you know that the engine control unit is no longer standard equipment? icon_cool.gif icon_wink.gif
Translated on 17-08-2026, 9:19.
mullemaus
Post13-04-2008, 16:53    Subject: WFS Issues After AWS Account Migration Quote
I have the full version here; I've licensed both versions and they are free for me to use.
I'm not talking about cracked versions. If you have a 'legitimate' 3xx series card, update it with the seller to a slightly newer 409. icon_wink.gif
I don't have the login code, and that is correct.
Then it might become difficult icon_wink.gif.
why shouldn't my engine control unit be in its original series configuration anymore?
Part and/or version: 1.9l R4 EDC G60SG MOZZ
Translated on 17-08-2026, 9:22.
Wiesel
Post13-04-2008, 18:31    Subject: WFS Issues After AWS Account Migration Quote
This here
... G60SG
would also worry me.
Ideally, there's an adaptation value that has been manipulated (normally, it shouldn't be).
00 to be; for example, 20 means that the idle speed has been adjusted.
Regarding your actual problem.
"Key not authorized" - occasionally, the problem may also be with the reading coil.
Take a look at the measurement blocks of the WFS (this should also be possible with version 3.11).
The error in the MSTG is just a consequential error.
Best regards, Micha.
Translated on 17-08-2026, 9:24.
[email protected]
Post26-08-2008, 21:15    Subject: WFS Issues After AWS Account Migration Quote
Is the error still active? Call me and we can talk about it. I've also had some issues. Phone number: 01702305097.
Westfalia tdi afn verlängertes getriebe
Translated on 17-08-2026, 9:25.
Back to top Profile PM Email
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
This topic is locked, you cannot edit or reply. AFN Conversion: Immobilizer Problems & Solutions On-Board Diagnostics (OBD)
No new posts Bordnet Steuergerät: Troubleshooting After Upgrade Electrical Systems, Vehicle Electronics, Multimedia
No new posts VNT17 Loader Conversion Problems: Troubleshooting Guide Diesel Engine Technology
No new posts Facelift Conversion Problems: ESP, Central Locking, Instr... On-Board Diagnostics (OBD)
