Audi A3 (8L): High Mileage Issues (Solution)
Michael II
Post08-01-2003, 12:18    Subject: Audi A3 (8L): High Mileage Issues Quote
The mileage counter is displaying an inexplicably high value.
Cause:
If terminal 30 (battery voltage) is disconnected for 2 to 3 seconds due to a faulty connection in the wiring harness, for example, some memory cells in the volatile memory will be erased for the distance traveled. If the power supply is interrupted for less than 2 seconds, all memory contents remain intact. If the period without voltage exceeds 3 seconds, an internal reset will occur. This will reload the correct values from the permanent memory into the volatile memory.
Solution:
If there is an inexplicably high total mileage reading, the control panel can be reset by disconnecting the fuse for approximately 2 minutes to restore the correct value.
If this procedure does not result in the correct distance being displayed, the control panel module needs to be replaced.
Tschüss
Michael II
Translated on 17-09-2026, 9:29.
Ratings - Audi A3 (8L): High Mileage Issues
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, valid until 03/2001, central locking, sin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Read True Mileage: How to Check Car Odometer On-Board Diagnostics (OBD)
No new posts Fake Mileage: Ibiza 6L Car Problems On-Board Diagnostics (OBD)
No new posts Check Passat 3BG mileage Electrical Systems, Vehicle Electronics, Multimedia
No new posts Mileage Meaning for Automatic Transmission - Block 109 On-Board Diagnostics (OBD)
