Help with measurement blocks for mass airflow sensor (MAF), lambda sensor
Das Unwissen
Avatar-Das Unwissen
Post28-12-2008, 1:12    Subject: Help with measurement blocks for mass airflow sensor (MAF), lambda sensor Quote
"Hi, could someone please explain to me how to measure the mass airflow sensor and the lambda sensor on a AJQ 1.8t engine, and specifically, how to do it while in 3rd gear, from 3000 RPM to 6000 RPM? My car has been running poorly for a while, and it seems like I'm experiencing power loss above 4000 RPM. I want to start figuring out what's causing the problem. The error memory isn't showing anything." Could someone please help me? Thanks in advance.
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts Can the embedded lambda probe be determined optically and... Electrical Systems, Vehicle Electronics, Multimedia
No new posts G60 Measurement Blocks: Specs & Applications Diesel Engine Technology
No new posts Measurement blocks A6 2.5 TDI V6 Diesel Engine Technology
No new posts Measurement blocks On-Board Diagnostics (OBD)
