Recoding the engine control unit
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
DaveA6
Post26-10-2008, 17:21    Subject: Recoding the engine control unit Quote
Hello everyone!
Here's a quick update on my renovation!
I've now wired everything up as much as possible and re-programmed the instrument cluster to the extent that I could.
Initially, I thought I wouldn't need a CAN connection between the MSG (Modular Signaling Device) and the instrument cluster, as my vehicle didn't have it before. However, I quickly realized that the WFS (Windshield Washer Fluid Sensor) also sends its signal to the MSG via this connection, so I installed those wires this morning.
If I try to start the engine now, it will briefly run and then shut off again.
The WFS (Wind Field Sensor) in the combination instrument is deactivated.
However, the MSG is still reporting an error, indicating that it is not receiving signals from the ABS control unit data bus and the transmission control unit data bus.
Unfortunately, I don't know what conditions must be met for MSG to not be blocked.
Okay, I'll provide the error messages now. I hope someone can clarify the situation.
First read after I connected everything:
VAG-COM Version: DRV 311.3-S
Control unit part number: 038 906 019 HM.
Component and/or version: 1.9L R4 EDC 0000AG 1601.
Encoding: 00001
Workshop code: WSC 02325.
Additional information: WAUZZZ4B43N110518 AUZ7Z0C2400661
5 error codes found:
18058 - Data bus drive, missing message from the instrument cluster.
P1650 - 35-10 - - - Intermittent.
17978 - Motor control unit locked.
P1570 - 35-00 - -
18057 - Data bus communication fault: No message received from the ABS control unit.
P1649 - 35-00 - -
18034 - Data bus malfunction: No message received from the transmission control unit.
P1626 - 35-00 - -
18043 - Data bus drive: Missing message from the climate control unit.
P1635 - 35-10 - - - Intermittent.
Control unit part number: 4B0 920 933 G.
Component and/or version: KOMBI+TRAVEL. VDO D12
Encoding: 00040
Workshop code: WSC 20599.
2 error codes found:
01177 - Engine Control Unit.
49-00 - No communication.
01304 - Radio
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Second data read after establishing the CAN connection between the instrument cluster and the MSG (Modular Signaling Device).
Encoding: 00001
P1570 - 35-00 - -
P1649 - 35-00 - -
P1626 - 35-00 - -
17849 - Exhaust gas recirculation (EGR) valve icon_cool.gif - Open circuit/Short to ground.
P1441 - 35-10 - - - Sporadically.
Encoding: 00040
"1 error found:"
01304 - Radio
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien. Die Blumen blĂŒhen in voller Pracht, und die BĂ€ume spenden angenehmen Schatten. Es ist eine Zeit der Freude und des GlĂŒcks."
Reading out the ABS control unit, which does not contain a CAN bus.
Control unit part number: 8E0 614 111 B.
Component and/or version: ABS/EDS 5.3 FRONT D10.
Encoding: 0273004283
Workshop code: BB 24332.
No error code found.
Post26-10-2008, 17:58    Subject: Re: Recoding the engine control unit Quote
DaveA6 wrote:
If I try to start the engine now, it will start briefly and then turn off again.
The condition is: a successful adaptation between WFS and MSG.
As long as that condition isn't met, this will keep happening as a consequence.
17978 - Engine control unit locked.
P1570 - 35-00 - -
DaveA6
Post26-10-2008, 18:16    Subject: Recoding the engine control unit Quote
Well, that's certainly a reliable statement!
The wiring is not entirely clear yet.
old AI:
Plug is green.
Pin 2 = Transponder 1.
Pin 4 = WFS
Pin 5 = W line.
Plug, blue.
Pin25 = K line.
new AI:
Plug is green.
Pin 2 = Transponder.
Pin 5 = W line.
Pin 28 = K line.
I connected pin 2 to pin 2, pin 5 to pin 5, and the pin 25 (blue connector) of the old instrument cluster to pin 28 (green connector) of the new instrument cluster.
Pin 4 = The WFS (Water Flow Sensor) of the old strand was not used. Is this okay so far?
The WFS light in the combination instrument turns off and remains off.
So, everything should be okay with the instrument cluster, right?
Does this mean that the information will not be transferred to my MSG device?
Post26-10-2008, 18:26    Subject: Recoding the engine control unit Quote
DaveA6 wrote:
Bitte gib den Text an, den du ĂŒbersetzt haben möchtest.
old AI:
new AI:
Does this then mean that the information will not be displayed on my MSG device?
If it says above
"The WFS in the combination instrument is deactivated,"
then I have to give up here due to a lack of detailed knowledge, but I suspect that with a "dead WFS-KI," you will never get the MSG to work...
DaveA6
Post26-10-2008, 18:32    Subject: Recoding the engine control unit Quote
What is a "Tote-WFS-KI"?
The question is, what exactly is dead here? If that's what you mean!
Post26-10-2008, 18:39    Subject: Recoding the engine control unit Quote
DaveA6 wrote:
What is a Tote-WFS-AI?
Well, it's this:
DaveA6
Post26-10-2008, 18:53    Subject: Recoding the engine control unit Quote
WFS is disabled = Lamp in the control panel turns off = WFS is not active.
However, it seems that this only applies to the KI system and not to the MSG system!
Post26-10-2008, 19:04    Subject: Recoding the engine control unit Quote
DaveA6 wrote:
WFS is disabled = Light in the cockpit goes out = WFS is not active.
However, I meant that this seems to be only the case in the AI, and not in the MSG!
Ah, I thought the WFS had been illegally removed.
If that's not the case, then the AI and MSG systems must simply be properly connected, compatible with the WFS generation, and trained to work together – and that's where I have to bow out due to a lack of detailed knowledge.
Karma: +436 / -0   Thank you, like it!
Post27-10-2008, 12:30    Subject: Re: Recoding the engine control unit Quote
DaveA6 wrote:
Component and/or version: KOMBI+TRAVEL. VDO D12.
49-00 - no communication
Since this message disappeared after the CAN bus was initialized, the MSG and KI (which is the WFS) can now apparently communicate with each other and seem to understand each other (I suspect they are using compatible hardware versions).
So, all that's left to do is to train the WFS to work with the MSG. Please search for information in the technical articles. There's an external link on Ross-Tech (or search directly there) that describes how to do this, depending on the WFS generation.
Guste.
PS: Why did you even bother to make any changes? I can't read anything about that in this thread.
DaveA6
Post27-10-2008, 13:07    Subject: Recoding the engine control unit Quote
I started the conversion because I had a 1.9L TDI engine with a rotary injection pump, and then suddenly, one of the cylinders lost compression. After a more thorough inspection, I discovered that a valve had broken off and was lying in the combustion chamber.
Since I was confident in my ability to upgrade to a slightly more modern engine generation, I started this conversion project.
However, I would advise everyone to never start something like that, because it's a bottomless pit.
I also suspect that, assuming the wiring is correct and the immobilizer is also deactivated in the instrument cluster, the problem likely stems from a communication issue between the instrument cluster and the engine control unit.
Is this the right way?
http://www.ross-tech.com/vag-com/cars/Immo3-measuring-blocks.html
mullemaus
Post27-10-2008, 14:11    Subject: Recoding the engine control unit Quote
There's nothing to disable in the combination instrument. You could install an American speedometer (which, depending on the year, may not have any warning lights), and the same thing would happen. You can expand it, but the same thing will happen.
So, all that's left is to train the WFS to connect to the MSG. Please search for information in the technical articles. There's an external link on Ross-Tech (or search directly there) that describes how to do this, depending on the WFS generation.
That's exactly right. The approval is coming from MSG. Regardless of which speedometer is installed (purely American models excluded icon_lol.gif).
WFS is disabled = Lamp in the dashboard turns off = WFS is not active
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.löschb. Fehler im MotorsteuergerÀt 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does the Audi A8 4H have an Advanced Key (Keyless Go)? Re... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts A6 C4 TDI MotorsteuergerÀt On-Board Diagnostics (OBD)
No new posts T5 MotorsteuergerÀt On-Board Diagnostics (OBD)
