Passat ABS/ESP Error: 2002 Model Troubleshooting
SirKitty
Post06-03-2009, 12:39    Subject: Passat ABS/ESP Error: 2002 Model Troubleshooting Quote
Hello everyone.
I hope you can help me.
I read the ABS control unit using VAG Com on a Passat from 2002 and cleared the error code "Implausible signal from the longitudinal acceleration sensor."
I then, unfortunately, went to the "Adoption" section and clicked "Read" on Canal 00 (only "Read" and not "Save").
Currently, the ABS warning light is always on, and the error log shows "System diagnosis active." It can be cleared, but it keeps reappearing.
Does anyone have any idea what's going on, or how to re-enable the system diagnostics?
I would be grateful for any help!
Translated on 25-10-2026, 7:59.
SirKitty
Post06-03-2009, 22:15    Subject: Done Quote
After a longer test drive, the lights turned off on their own.
Translated on 25-10-2026, 8:00.
No new posts Audi A2 Electrical Door Lock Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Air Conditioning Fault 1206 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Particulate Filter Error 2002 Diesel Engine Technology
No new posts Passat TDI 2002: Euro 3 Specs & Info Diesel Engine Technology
No new posts Passat 1.9 TDI: Buying Guide & Review Diesel Engine Technology
No new posts Passat CLIMAtronic Reset: 2002 Model On-Board Diagnostics (OBD)
