Performance difference with and without LMM
Johannes
Post04-05-2002, 13:24    Subject: Performance difference with and without LMM Quote
Since I'm missing power in my V6 110 kW, I removed the air mass sensor. Subjectively, I haven't noticed any difference in performance. Does anyone know how much the 'Notprogram' costs? Is it noticeably apparent?
If so, then my LMM is probably broken.
How can I test the LMM?
Avatar-Jan6K
Post04-05-2002, 13:33    Subject: Should Quote
Then, apparently, there was some kind of... The 1.9-liter engine with 110 horsepower was supposed to have a "not" program that, if I remember correctly, would bring the power down to around 60...70 horsepower, so there's a significant difference.
Jan
1Z5 CFHF / AHB H4D
Post04-05-2002, 19:51    Subject: Re: Performance Difference with and without LMM Quote
Johannes wrote:
Because I'm missing power in my V6 110 kW, I recently disconnected the air mass flow meter (LMM). Subjectively, I didn't notice any difference in performance. Does anyone know how much the "not program" costs? Is it noticeably apparent?
At least the AFN (81kW) seems to work like a sleeping pill when disconnected from the grid.
Can this be directly applied to the V6...?
Maybe another V6 owner could also take a test drive with the LMM disconnected and post the results.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts ESP not working On-Board Diagnostics (OBD)
No new posts EPC without any errors On-Board Diagnostics (OBD)
No new posts 2x2 diagnostic adapter without +12V On-Board Diagnostics (OBD)
